Lude Posted October 11, 2010 Share Posted October 11, 2010 my car has a Blitz FCD. now im not sure whats hapening in 1st gear, its sorta like when i floor it hard/sharp sometimes, im hitting the limiter, but not at 7rpm or whatever the stock limit is, its like fuel cut. my car does overboost a lot, and am trying to get a correct Restrictor ring, is my FCD broken? i can acheive up to 1.4bar of boost in all the other gears, so if the FCD was broke would this be possible? PS its only sometimes this occurs, if i do a drag start im fine? im not 100% its fuel cut, but its asif its bouncing off the limiter at a lower RPM than stock? Quote Link to comment Share on other sites More sharing options...
