Chris Wilson Posted February 7, 2011 Share Posted February 7, 2011 No worries, and thanks for the trader rating feedback Link to comment Share on other sites More sharing options...
pedrosixfour Posted February 17, 2011 Author Share Posted February 17, 2011 Power steering reservoir, accelerator cable, down pipe and oxygen sensor now sourced. Thanks little num! 1st post updated. Link to comment Share on other sites More sharing options...
pedrosixfour Posted February 18, 2011 Author Share Posted February 18, 2011 1st post updated. Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 8, 2011 Author Share Posted August 8, 2011 In need of the following: TT PS Pump suction hose and union. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2011 Share Posted August 8, 2011 You should definitely buy a new suction hose, they go hard and don't seal on the unions properly, and draw air, making the pump noisy and the steering notchy. I don't think they are very dear. Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 8, 2011 Author Share Posted August 8, 2011 Chances are I may be forced to buy both parts new Chris as I can't imagine they are parts people find they have a couple of spare. Link to comment Share on other sites More sharing options...
little num Posted August 8, 2011 Share Posted August 8, 2011 I have 2 but both are hard and splitting so new is the only way, will be around £12 id have thought. Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 8, 2011 Author Share Posted August 8, 2011 I have 2 but both are hard and splitting so new is the only way, will be around £12 id have thought. Any chance that there is one of the little fittings knocking around James? Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 12, 2011 Author Share Posted August 12, 2011 I ordered these parts new today from Toyota, along with six coil plug connectors and a pair of cam cover gaskets for the 1JZ. Total was €120 plus 21% VAT, which isn't too bad at all. So don't come along now and tell me you have one sitting in the garage that I'm welcome to! Link to comment Share on other sites More sharing options...
David P Posted August 12, 2011 Share Posted August 12, 2011 Guess what! Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 30, 2011 Author Share Posted August 30, 2011 Bump for new part needed Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 31, 2011 Author Share Posted August 31, 2011 And again cos I'm in a pickle. Parts needed in first post. Link to comment Share on other sites More sharing options...
pedrosixfour Posted September 1, 2011 Author Share Posted September 1, 2011 Chris Wilson is sorting me out with an ignitor pack shortly and I've just ordered a fair quantity of silicone hoses in various shapes and sizes, hose joiners, mikalor clips and a little bit of ducting to see if I can't make use of the NA airbox that I have to sort out a cold filtered air feed to the turbos and a boosted air feed through the SMIC to the manifold. I hope this works! Link to comment Share on other sites More sharing options...
pedrosixfour Posted September 9, 2011 Author Share Posted September 9, 2011 TT Ignitor arrived today Chris. Thank you very much indeed sir. Any luck on the sump plug adaptor? Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 9, 2011 Share Posted September 9, 2011 I will check tomorrow, to be honest I forgot. I *think* I have one! Link to comment Share on other sites More sharing options...
pedrosixfour Posted September 13, 2011 Author Share Posted September 13, 2011 I will check tomorrow, to be honest I forgot. I *think* I have one! Any luck (look) Chris? Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 1, 2012 Author Share Posted May 1, 2012 Time to bump this thread again as I'm looking for the extra diff mount which secures the diff to the subframe in a turbo model but which was felt (by Toyota) to be unnecessary in a non turbo model. As I'm now running a 1JZ I feel this might now be a worthwhile investment. Thanks for looking and I hope someone can help. Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 3, 2012 Author Share Posted May 3, 2012 Bump I suggest you all check here => Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 3, 2012 Share Posted May 3, 2012 I may have a stepper motor, would need to test it on a car though. Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 3, 2012 Author Share Posted May 3, 2012 I may have a stepper motor, would need to test it on a car though. Well I may be hung like a donkey Chris but what the devil does either have to do with a diff mount for my subframe?? Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 3, 2012 Share Posted May 3, 2012 You tell me! God knows what's happened here Anyway, you well endowed Irishman, do you want a stepper motor or not? Link to comment Share on other sites More sharing options...
little num Posted May 5, 2012 Share Posted May 5, 2012 Im going to get some 10mm plates made up and weld them into the holes (getting rid of the rubber mounts) so it will be bolted still but a fixed rear as its worn bush's that cause wheel hop and i have lot of that due to 1 bush and thats all split. Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 5, 2012 Share Posted May 5, 2012 Do you still need a PAS reservoir? I don't have any OE ones, but have some nice fabricated alloy tanks with Aeroquip threaded male stubs and fabricated lightweight steel brackets that would work well as a PAS tank or coolant header tanks. Could be polished to look blingy Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 5, 2012 Author Share Posted May 5, 2012 Im going to get some 10mm plates made up and weld them into the holes (getting rid of the rubber mounts) so it will be bolted still but a fixed rear as its worn bush's that cause wheel hop and i have lot of that due to 1 bush and thats all split. I was thinking of doing/getting something similar myself mate if a good used mount couldn't be found. But even if I could get my hands on an old shot unit it would be handy for taking accurate measurements from to get a pair made. Do you still need a PAS reservoir? I don't have any OE ones, but have some nice fabricated alloy tanks with Aeroquip threaded male stubs and fabricated lightweight steel brackets that would work well as a PAS tank or coolant header tanks. Could be polished to look blingy Thanks for the offer Chris but it's only the diff mount I am looking for at the moment. Forgive the messy thread, I always update the first post with whats currently needed. Link to comment Share on other sites More sharing options...
pedrosixfour Posted May 11, 2012 Author Share Posted May 11, 2012 It's a bump Jim, but not as we know it. Link to comment Share on other sites More sharing options...
