Grinding noise
LOGIE
Hi folks a little help needed, I just changed my suspension as I had a leeking shock absorber so I fitted yellow bilsteins with springs and top mounts and all is good there however now when i put my right lock on im getting a gringing noise (metal to metal) from my front left wheel. I took the wheel off and checked my pads discs etc all seems fine. Im running stock 16's so no rubbing issues and when the car is jacked up and full lock is on there is no grinding, so its only when the car is on the ground im getting this noise. :( any suggestions? before I take it to a garage.
Many thanks in advance.
