randy Posted December 22, 2002 Share Posted December 22, 2002 Hi guys! The parking brake light keeps coming on and off when I drive? Is there some lose wire I can check? What should I look for? Quote Link to comment Share on other sites More sharing options...
Thorin Posted December 22, 2002 Share Posted December 22, 2002 You sure it's not just low brake fluid? The same light comes on as the parking brake I think. Quote Link to comment Share on other sites More sharing options...
suprarob Posted December 23, 2002 Share Posted December 23, 2002 the brake system waning light has three functions it tells you that you have got the hand bake on. If it comes on when you brake only, it means you have a stop light blown. If it comes on and stays on and you haven,t got your hand brake on it means your brake fluid is low this is what it says in the uk owners manual. Quote Link to comment Share on other sites More sharing options...
randy Posted December 27, 2002 Author Share Posted December 27, 2002 Thanks! Brake fluid was low, filled up with DOT 4 brake fluid and light went off. Quote Link to comment Share on other sites More sharing options...
Terminator Posted December 27, 2002 Share Posted December 27, 2002 Randy if your fluid has dropped that low, it might be worth checking the pads to see how far they have to go. Quote Link to comment Share on other sites More sharing options...
randy Posted December 27, 2002 Author Share Posted December 27, 2002 My front pads are pretty new. only just replaced when I did the UK brake upgrade. The rears also have a bit to go. I guess we did not fill enough brake fluid when we changed the brakes. Thanks! Quote Link to comment Share on other sites More sharing options...
