Supralad Posted October 8, 2010 Share Posted October 8, 2010 Last night i was driving home and noticed there was a rather bad draft coming through by the drivers door handle. Bad enough that I thought it was the aircon. Also in the mornings the windows have full condensation on the inside as well - i seem to think this is linked. Anyone else had this problem? Link to comment Share on other sites More sharing options...
nasoup Posted October 8, 2010 Share Posted October 8, 2010 Has this happened since you'v owned the supra or has it gradually got worse? Link to comment Share on other sites More sharing options...
Supralad Posted October 8, 2010 Author Share Posted October 8, 2010 Has this happened since you'v owned the supra or has it gradually got worse? never noticed it before - had the car 3 months Link to comment Share on other sites More sharing options...
Terminator Posted October 8, 2010 Share Posted October 8, 2010 (edited) Sounds like the car is damp inside. Do you have working aircon if so it should shift the moisture pretty fast. Check your passenger foot well area. Leave the aircon on all the time it should keep the inside dry unless you have a problem. Sounds like the membrane inside the door is holed or missing. Edited October 8, 2010 by Terminator (see edit history) Link to comment Share on other sites More sharing options...
nasoup Posted October 8, 2010 Share Posted October 8, 2010 Sounds like the membrane inside the door is holed or missing. That's what I thought but I have no membrane in my drivers door but never had an issue with moisture or cold air blowing through Link to comment Share on other sites More sharing options...
Nic Posted October 8, 2010 Share Posted October 8, 2010 Some suggestions, check horizontal door/window seals, door frame seal and the rubber boot around the wiring that goes into the door. Also check if the bottom of the door card is damp, if the window seal is leaking, water will get past and into the door. Link to comment Share on other sites More sharing options...
L18msy Posted October 8, 2010 Share Posted October 8, 2010 Sounds like the membrane to me. If the membrane is holed or missing you will get a draft through the handle and you will also get water ingress causing condensation. I had this problem when i bought mine and i rectified it with a new membrane. Link to comment Share on other sites More sharing options...
Homer Posted October 8, 2010 Share Posted October 8, 2010 Sounds like the membrane to me. If the membrane is holed or missing you will get a draft through the handle and you will also get water ingress causing condensation. I had this problem when i bought mine and i rectified it with a new membrane. This is almost certainly the problem The key is that you're getting a draft through the door handle which is a sure sign the membrane has a split is is not fully secured. Easy thing to fix though, remove the door card and check the membrane is fully secured, in most cases it'll either be a previous owner removing/cutting it for audio components, or just part of it becoming detached. Link to comment Share on other sites More sharing options...
dude Posted October 9, 2010 Share Posted October 9, 2010 Check the grommets in the front of the door, where the wiring loom passes from door to car. Link to comment Share on other sites More sharing options...
DamanC Posted October 11, 2010 Share Posted October 11, 2010 This is almost certainly the problem The key is that you're getting a draft through the door handle which is a sure sign the membrane has a split is is not fully secured. Easy thing to fix though, remove the door card and check the membrane is fully secured, in most cases it'll either be a previous owner removing/cutting it for audio components, or just part of it becoming detached. Win I stuffed some front speakers in both my door cards and get said draft, I also suffer from condensation build up. Looks like I will be investing in some new membranes, anyone have the part number? Link to comment Share on other sites More sharing options...
Scott Posted October 11, 2010 Share Posted October 11, 2010 Win I stuffed some front speakers in both my door cards and get said draft, I also suffer from condensation build up. Looks like I will be investing in some new membranes, anyone have the part number? Poly bag and some gum, job done I have the membranes but if I didn't I would just go with some plastic. Link to comment Share on other sites More sharing options...
