mellonman Posted October 8, 2010 Share Posted October 8, 2010 strange one but i have just fitted stage 3 hybrid turbos they seem fine but do have a problem that i want to get sorted before i see ryan for ecu and map, what i get is lets say first turbo spools and i get boost reading 0.8 at 3000rpm but not the power then get a serge of power a little later (this feels like a smaller kick like what you get with the bpu second turbo) then the second turbo comes in at 5000rpm and i tearing up tarmac at worp speed. im not sure if this happends every time is this just lag from the bigger and heavier turbo internals should i just replace all vacuem pipes could this be the egbv sticking? when it was all apart it seemed to be free and working just fine. Link to comment Share on other sites More sharing options...
Robzki Posted October 8, 2010 Share Posted October 8, 2010 Probably not the same, but I went bpu a month ago, I was hitting 0.7 on the first turbo but didn't seem to have the same power as b4, but had a good kick when the second came in. It turned out that because the car had been sitting for 6 weeks that the rear brakes were binding fairly badly. was strange because you couldn't feel them binding, possibly a mixture of the power and weight of the car. jacked the car up and could only just turn the hubs by hand. freed them off and the difference was immense. Link to comment Share on other sites More sharing options...
mellonman Posted October 8, 2010 Author Share Posted October 8, 2010 this could be the case as it was sitting out in the rain for 2 weeks while i was waiting for the turbos to done i will have to have a check Link to comment Share on other sites More sharing options...
Robzki Posted October 8, 2010 Share Posted October 8, 2010 It sounds weird I know, But its strange to be making strong positive boost, but to not feel a surge. It had me confused for a while, I checked all pipes etc and thought that I was imagining it. Mine is auto, If it was a manual I'd think that this would be easier to diagnose. Link to comment Share on other sites More sharing options...
mellonman Posted October 8, 2010 Author Share Posted October 8, 2010 yeah i know im a auto as well does make sence though cos it does seem to be changing gear wrong as well dropping a gear abit to easy as soon as you said brakes i was like omg of corse i should of checked that Link to comment Share on other sites More sharing options...
Robzki Posted October 8, 2010 Share Posted October 8, 2010 Lol, I had a similar blonde moment, checked everything techy rather than checking the easiest things first. Also because the car has some momentum by the time the second turbo kicks in, you can feel the surge then. Link to comment Share on other sites More sharing options...
mellonman Posted October 14, 2010 Author Share Posted October 14, 2010 right i checked the brakes all are free, but still seem to get this problem i get 0.6 boost at 3000 rpm but power only seems to come at after 3500 rpm if i accelarte slowly it seems to build boost normally but if i put my foot down a little more it has nothing and then a kick at 3500 and then again at 4700 with second turbo. Link to comment Share on other sites More sharing options...
mellonman Posted October 15, 2010 Author Share Posted October 15, 2010 had my friend have ago last night who also have hybrid and he said they are the same as his so its that they are just LAGGY Link to comment Share on other sites More sharing options...
Robzki Posted October 15, 2010 Share Posted October 15, 2010 In that case an ecu and map will no doubt sort it. Are you monitoring egt and afr's? Link to comment Share on other sites More sharing options...
