cheap ebay engine gasket set?
Oddball87
another thing to be carefull of is that many non original head gaskets dont have the water and oil channels cut out of them correctly (position and sizes). you might get away with some of the gaskets but as said above, its never worth the risk tbh
i did an GT4 engine rebuild for someone who got the kit from the same seller, although the kit proved ok,and is still going strong ,he also got the head bolts from there which were shocking to say the least a few of the bolts had no torx heads & the ones that did were so far off centre of the bolt that they would of probably snapped when being torqued down. seem to remember the kits are made in Spain. Would,nt use them
