Wheel Offset
Jellybean
Spacers
Project Kics Wide Tread Wheel Spacers Type:10mm / 5 X 114.3mm (FRONT)
Project Kics Wide Tread Wheel Spacers Type:25mm / 5 X 114.3mm (REAR)
Wheels
Volk Racing GT-C Face 2 Wheels Size:5X114.3 19X10.5J ET+37 (REAR)
Volk Racing GT-C Face 2 Wheels Size:5X114.3 19X9.5J ET+24 (FRONT)
Is it correct to say the correct offset of my wheels is as simple as subtracting the Spacer MM from the Wheel Offset?
So
Front is +24 - 10 = +14
Rear is +37 - 25 = +12
Would +14 offset on the Front clear UK Brakes?
Sorry I am a bit confused ; if the wheel Width is constant and the offset is just changing to negate the need for the spacer, how will this affect the arch clearance ? Surely the wheel wont move within the arch
Am I right in saying having +14 offset as oppsed to +24 offset, I will have a deeper dish?
If you had 1 set (with the above offsets - 19X10.5J ET+37 / 19X9.5J ET+24) and you put spacers on, yes the wheel will move inside the arch because you have brought it out from the centre of the car and so towards the outer arch.
If the question was more related to choosing between say 2 sets of wheels with different offsets, then yes the offset will change the dish whilst keeping the wheel relatively in the same position inside the arch. :)
