Vi-pec ECU with BL auto and hi-stall converter?
CroSupra
ViPec is just a rebadged Link G4. These can be made to run with an autobox piggy backed but ignition retard prior to gear change can only happen with a small box monitoring the S1 and S2 solenoids and informing the piggy back ecu so it can change maps. The Syvecs has been made to work with it without the need for a small box but the best option is the PCS autobox controller, then you can run what ever set up you like and map the box to shift like you want it to and enjoy the paddle shift option if required.
