craig l Posted October 4, 2010 Share Posted October 4, 2010 My ps pumps been whining for a few weeks now only for a couple of minutes on start up then its fine. Tryed bleeding it didnt work. Started it tonight now its whining and grinding really bad steering wheel hardly moves at low revs, moves a bit with higher revs ive bought one from richardstock1 which should come in a couple of days. What damage will it cause if i drive it cos i'll park it up until its fixed. Link to comment Share on other sites More sharing options...
Terminator Posted October 4, 2010 Share Posted October 4, 2010 If you can I would leave it until you can swap it. Not sure but you might end up with fragments of pump around the system, probably best avoided. Link to comment Share on other sites More sharing options...
SteveC Posted October 4, 2010 Share Posted October 4, 2010 Are you sure that the filter in the reservoir isn't blocked? If it is, then you will get the symptoms you have described. Link to comment Share on other sites More sharing options...
craig l Posted October 4, 2010 Author Share Posted October 4, 2010 Thanks guys i wasnt going to drive it anyway not with that noise i'll check the filter tommorrow. Link to comment Share on other sites More sharing options...
Swampy442 Posted October 4, 2010 Share Posted October 4, 2010 Yeah filter first and flush the old fluid out. I bet its stinking and brown Link to comment Share on other sites More sharing options...
craig l Posted October 5, 2010 Author Share Posted October 5, 2010 right call me thick had a look today how do you get the filter out its a sealed unit Link to comment Share on other sites More sharing options...
VIL Posted October 5, 2010 Share Posted October 5, 2010 No it is sealed in the reservoir. There are a few threads on here on about the best way to clean it. I had a PAS failure, steering very noisy and got progressively heavier until it was almost solid and eventually it started to pi$$ PAS fluid all over the place. Link to comment Share on other sites More sharing options...
SteveC Posted October 5, 2010 Share Posted October 5, 2010 Take the reservoir off and clean it out with something - I used petrol. The filter doesn't come out, just gently use a small paint brush on it to loosen the goo stuff. Link to comment Share on other sites More sharing options...
craig l Posted October 5, 2010 Author Share Posted October 5, 2010 Thank you again guys. Link to comment Share on other sites More sharing options...
craig l Posted October 5, 2010 Author Share Posted October 5, 2010 Right i took off reservoir cleaned it out tryed bleeding it again still no better sounds like the belts under a lot of stress, eases off a bit with higher revs must be the pump. Link to comment Share on other sites More sharing options...
Terminator Posted October 5, 2010 Share Posted October 5, 2010 (edited) Are you hoses modified in any way? I had to lengthen mine due to moving my reservoir. Under load one of the hoses collapsed the noise was terrible, steering very heavy. Thought I had blown the pump. New hose sorted the problem. You need someone to check the hoses while you turn the steering wheel. I was working on the car by myself so only spotted it when I got someone the turn the wheel for me. I was about to condemn the pump. Edited October 5, 2010 by Terminator (see edit history) Link to comment Share on other sites More sharing options...
craig l Posted October 5, 2010 Author Share Posted October 5, 2010 Im bpu but the hoses and everything else are standard never been moved the mots due in two days dont want to move it until its fixed. Link to comment Share on other sites More sharing options...
