Rear main seal PART NUMBER
spiderpigcity
Does anyone have the part number
http://www.mkivsupra.net/vbb/showthread.php?t=209667
and price for the rear main crank seal on auto tt?
http://www.mkivsupra.net/vbb/showthread.php?t=215166
Is it an easy job on the ramps wih the box off? Or is it a pig?
Yeah it's pretty straightforward on a ramp, just make sure you don't scratch/kink/damage the seal getting it in - but be sure it's fully back far enough.
http://www.mkivsupra.net/vbb/showthread.php?t=209667http://www.mkivsupra.net/vbb/showthread.php?t=215166 Yeah it's pretty straightforward on a ramp, just make sure you don't scratch/kink/damage the seal getting it in - but be sure it's fully back far enough.
cheers, i am just presuming its the seal as i have oil dripping very slowly out of the drain hole in the bottom of the auto box where it faces up to the block
thanks for the help
matt
thanks for the help
matt
Cam cover gaskets can also be a cause of this. The oil seeps out and runs down the back of the engine block. Might be worth checking ;)
