Turbo Timer//Boost Indicator
kubus1
Hi All,
I have just fitted my Blitz DATT Turbo Timer. It works fine as the timer, but it doesnt show the boost levels.
I know I have to connect it to the boost sensor(??). Is that right?
And how do I do that? I have got one rubber hose left from the kit,and I guess that should connect somewhere on the Turbos, But no idea where.
All help will be appreciated.
Thanks,
Cuba
Originally posted by kubus1
Hi All,
Thanks,
Cuba
I would go to http://www.mkiv.com in the tech articles section. There is a section on fitting a boost gauge, see if that helps
Right, I followed the steps from MKIV.com.
There is one thing though.
There is one hose then you ve got the Y joint and there are two other hoses, One goes to Turbo Pressure sensor and the other connects to the Throtle body just aft of the sensor.
Now, if I use the T joint to get my hose to the turbo sensor what do I do with the other hose. I m sure its there for a reason and should not be left unplugged.
Please bare with me if I sound thick but I m not very good with those things.
Thank you again.
Cuba
Ok Guys,
I think I just realized what I was doing wrong.
Thanks for all your help, I ll try it again tomorrow and I think I ll be fine.
Thanks again. Its always good to know that if I m in trouble with something I can always get an answer here.
Cheers,
Cuba
