mobius Posted October 3, 2010 Share Posted October 3, 2010 Quick question got my car in Febuary this year and noticed that the door glass froze itself to the door rubbers, making it impossable to get in (had to climb in over the back seats) Is there any 'lubricant' to prevent this, ( que sexual the comments) Vasalene is oil based so would perish the rubbers The other Lubricant available are water based so any other suggestions Quote Link to comment Share on other sites More sharing options...
Mcgoo Posted October 3, 2010 Share Posted October 3, 2010 Silicone grease does the trick. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted October 3, 2010 Share Posted October 3, 2010 Keep it in a garage? Any petrolium based lube will be fine Quote Link to comment Share on other sites More sharing options...
mobius Posted October 4, 2010 Author Share Posted October 4, 2010 Cheers will try and get some silicone grease, wish I had a garage:( Quote Link to comment Share on other sites More sharing options...
supra_bus. Posted October 4, 2010 Share Posted October 4, 2010 i got a garage goes in fine but cant get out the car then DOH!! Quote Link to comment Share on other sites More sharing options...
Abz Posted October 4, 2010 Share Posted October 4, 2010 Remote engine start should sort that out Or Silicone grease. Quote Link to comment Share on other sites More sharing options...
Westcoaster Posted October 4, 2010 Share Posted October 4, 2010 (edited) Keep it in a garage? Any petrolium based lube will be fine Bad idea, petroleum jelly etc will rot rubber. Get a pot of Hepworth's silicon grease from a plumbers merchant or 3 in 1 silicon oil in an aerosol and keep it in the garage. An application of silicon grease or oil will also stop the rubber blocks squeaking on the tailgate surround. Silicon oil is the correct lube for car locks too. Edited October 4, 2010 by Westcoaster (see edit history) Quote Link to comment Share on other sites More sharing options...
Havard Posted October 4, 2010 Share Posted October 4, 2010 Remote engine start should sort that out No it won't, my car froze up in February and after a 30 minute drive the drivers door was still stuck solid.... I got in through the passenger side before anyone asks? The scary thing was that on the return journey home, my door unlocked itself at 80 Leptons.... H. Quote Link to comment Share on other sites More sharing options...
supra steveo Posted October 4, 2010 Share Posted October 4, 2010 dont use the doors climb in through the boot Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted October 4, 2010 Share Posted October 4, 2010 Good idea with the silicon. Just don't have any paintwork done for a while after.. Quote Link to comment Share on other sites More sharing options...
Nicolai Posted October 10, 2010 Share Posted October 10, 2010 If you smear some rain-x (wich normaly for your windows) on the places where it gets stuck normally, that will do the trick. Or the grease wich the cheaper option. Quote Link to comment Share on other sites More sharing options...
