2soops Posted October 1, 2010 Share Posted October 1, 2010 Hi All Had a 6spd conversion done a while ago and am just trying to confirm whether i now have an LSD. Spoke to Toyota this morning and they have given part no 41110-14730 as the diff from the donor car, but couldn't tell me what type it is. Do any of you Supra Guru's out there recognise or have come across this part number Cheers:search: Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 1, 2010 Share Posted October 1, 2010 Just find an empty space put the car on full lock and light the rears up, if both spin you have an lsd, if only the inside unloaded wheel spins you dont Quote Link to comment Share on other sites More sharing options...
The Raven Posted October 1, 2010 Share Posted October 1, 2010 No to lsd drugs are bad mkay! Didnt most have Lsd? Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 1, 2010 Share Posted October 1, 2010 No to lsd drugs are bad mkay! Didnt most have Lsd? Majic mushrooms, hmmm those were the days Lucy in the sky with diamonds Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted October 1, 2010 Share Posted October 1, 2010 Jack it up, turn one of the rears by hand. If the other doesnt move, you should be good Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 1, 2010 Share Posted October 1, 2010 IMHO the only sure way to know with Torsen type diffs is to pull the back cover off and have a look inside, or use a borescope through the level plug hole. Quote Link to comment Share on other sites More sharing options...
2soops Posted October 1, 2010 Author Share Posted October 1, 2010 Jack it up, turn one of the rears by hand. If the other doesnt move, you should be good Just given this a go and yes if you turn one wheel the other dosen't move. I thought with an lsd they were both mean't to turn the same way and non lsd turn opposite ways. Hope nothings broken!!! Quote Link to comment Share on other sites More sharing options...
2soops Posted October 1, 2010 Author Share Posted October 1, 2010 IMHO the only sure way to know with Torsen type diffs is to pull the back cover off and have a look inside, or use a borescope through the level plug hole. This is a bit advanced for me, im just a bloke working in his garage at home. I don't have a boroscope and even if i did i wouldn't know what the differences were to look at. Are you saying though that you can have an lsd or non lsd in the same outer casing, hence looking inside. Apologies if i sound a bit thick, im not, i just don't know much about the internal workings of supra diffs, or any others for that matter. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted October 1, 2010 Share Posted October 1, 2010 If you don't know, Or can't tell, does it really matter? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 1, 2010 Share Posted October 1, 2010 Yes, the casings can be the same. If it was an unmolested car the chassis plate would tell you, but if it's a "bitsa" unless you know the chassis plate of the diff's donor car, you need to look inside. Torsen diffs have little preload, so until there is a torque reaction (driving hard with dissimilar grip on the two back tyres) not much happens, so they feel like an open diff. Even when working properly they don't do much, unlike a more performance orientated type such as a plate type LSD. These are unpopular on all but 4 x 4's as they can clunk and judder. If you brought it to me for a service I could have alook inside it for you Google Torsen to see how they work and what they look like inside. Quote Link to comment Share on other sites More sharing options...
2soops Posted October 1, 2010 Author Share Posted October 1, 2010 I might just bring it up to you one of these days, long way from Oxford though Quote Link to comment Share on other sites More sharing options...
SteveL Posted October 1, 2010 Share Posted October 1, 2010 Chris is right - its difficult to tell! I was convinced I hadn't got a Torsen in mine originally, but it was. I did the tests described an it looked like it wasn't. Quote Link to comment Share on other sites More sharing options...
