Gear stick - sloppy movement.
fuldhat
Hi
Have noticed that the Gear stick/selection is a bit sloppy.
When I have in gear, then I can still move it left and right about 5 cm`s in total.
And also the gearchange don´t seem very "tight"
What do I need to change to get this back to normal?
Thanks.
I'd go with Swampy's suggestion - worn/blown out nylon shifter mechanism bushes. w58/v16*/r154 all have them. They can be a bit of a pain to swap as the rear of the box will ideally to be dropped down. They're about £10 each (two needed) and need a bit of compression to get fitted.
