mark newman Posted September 30, 2010 Share Posted September 30, 2010 Hi, What's the procedure of moving the standard breather connector on the cam cover, left side. I need it to face backwards instead of fowards i have tried to spin it but it's solid. I have tried this on a spare cover and it moves fairley freely. Quote Link to comment Share on other sites More sharing options...
Lude Posted September 30, 2010 Share Posted September 30, 2010 i used a screw driver, and sorta leavered it off, get me? like wedge it in the gap where the pipe meets the cam cover, and leaver Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted September 30, 2010 Share Posted September 30, 2010 i used a set of adjustables so the reached over the tube part and worked it,it will give. Quote Link to comment Share on other sites More sharing options...
mark newman Posted September 30, 2010 Author Share Posted September 30, 2010 i used a screw driver, and sorta leavered it off, get me? like wedge it in the gap where the pipe meets the cam cover, and leaver What so are these just pushed in? As in is there a nut behind or anything? Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted September 30, 2010 Share Posted September 30, 2010 What so are these just pushed in? As in is there a nut behind or anything? correct. Quote Link to comment Share on other sites More sharing options...
mark newman Posted September 30, 2010 Author Share Posted September 30, 2010 Ok thankyou, i will give it another go tomorrow. I just didnt want to apply to much pressure and have something snap on me. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted September 30, 2010 Share Posted September 30, 2010 Ok thankyou, i will give it another go tomorrow. I just didnt want to apply to much pressure and have something snap on me. you have a spare one so dont worry too much it will work free just corrosion build up holding it tight mine was the same. Quote Link to comment Share on other sites More sharing options...
Geo Posted September 30, 2010 Share Posted September 30, 2010 pliers, grab it, turn it round, simple. needs some muscle on it Quote Link to comment Share on other sites More sharing options...
Homer Posted September 30, 2010 Share Posted September 30, 2010 Edit ignore, me. Just figured it out! As others have said, it can either be pulled out or rotated. It's damn tight so might be worth putting a suitably sized bolt in there before compressing it with a clamp any trying to rotate it Quote Link to comment Share on other sites More sharing options...
