Random no boost on WOT
pistonbroke
It's happened three times now, the first I put down to a hiccup in the system, but it's done it a further two times under the same circumstances so I thought I'd ask here for any pointers.
When travelling down the road at a steady pace off boost, if I drop a gear and give it full throttle, I get no boost at all......nothing. If I then take my foot off the accelerator and re-apply, it boosts fully as it should.
I've checked all the hoses, they are fine (they've all been replaced). I've just cleaned up the VSV's with some carb cleaner, but not re-tested yet, is there anything else I should look at.
Having searched a bit, I've come across this pressure tank thingy, I understand it's under the inlet manifold towards the rear of the engine? Could this be something I should look at?
That's one of the top VSVs causing that bud. Iirc it's the very small one right at the top of the engine. It's a very common problem. It doesn't react quick enough or something like that. Changing mine out cured the problem.
I would be surprised if it was the pressure tank. Quick way to check that is to put it into the temporary TTC mode. Take it for a quick on boost spin then check if the actuators are still open, if they are your pressure tank is fine.
Yup, it was no.7 that was my issue bud. Try and borrow one to see if it fixes it.
Make sure you can re-create the fault with yours quite regularly though. When your dropping down a cog make sure you go from making next to no boost.. to 4krpm+ when you drop. 6th to 3rd always works well :D
