Auto gear shifter illumination?
colmcork
Yes they should be lit up, i believe there is 1 bulb underneath which probably has a green condom style thing over it. You will need to remove that dash piece surround, it should be fairly obvious. 1 tip though, start by removing the ash try and i'm sure you will find a screw underneath that will need undoing first to get it out :)
