(Auto Electrics) How to read Ohms?
Jake
I'm trying to find a fault on my bike. I suspect the Crank Position Sensor might be faulty.
the workshop manual says across the two pins on the plug from the CPS I should have 248 ~ 372Ω with "Tester selection position at Ωx100"
Now, my voltmeter doesn't have a Ωx100 setting but it has Ω settings for 200, 2k, 20k, 200k, 2m
When I test the CPS plug terminals using setting 200Ω the digital display just shows "1" - which means Out Of Range/Off Scale I believe.
When I test the CPS with setting 2k it shows "0.89"
And 20K shows "0.9"
Anyone know what's going on here? I'm totally confused.
As you can tell, I know nothing about electrics.
Thanks
As 2K and 20K should be 0.89 - 0.089 respectively
Why should it? I don't understand that. It's a digital meter, if it's within range it should display the correct reading not some 10x 100x multiple - shouldn't it? (I dunno just seem logical)
Sounds like it is open circuit bud. Does it say anything after the 0.89? Such as M or G?
It will either be less than 1 ohm or 890ohms IMO. Either way its fooked. Going by the 200 being out of range it would appear to be 890 ohms.
Makes sense. Thanks.
I hope it is fooked cos that means I've found the problem at last. At the other end of the wires reading from the solder points on the CPS itself I was getting a reading of just over 300 Ohms.
on the 2k setting you need to look for 0248 ~ 0372 or 0.248 to 0.372 etc
So it is a multiple, how odd.
thanks chaps.
Are you sure your reading it properly or using the correct pins.
I just checked it again and now it's reading
.285 (No leading zero) at 2k setting
and
0.29 (with leading zero) at 20k
and
00.3 at 200k (two leading zeros)
and
1 at 200
So it must be 285 Ohms I guess.
Which means I haven't found the fault. Bugger.
