facelift clocks in prefacelift
jackso11
I know this has been talked about a lot and the end result is 'massive job, different looms'.
My question is, the facelift turbo clocks have a boost guage that is pretty cak and I pressume the look change for that would be difficult. However, if I were to put facelift clocks in a pre facelift that but sourced the clocks from a non-turbo would that be an easier change? I am guessing the volt meter is just a positive feed going in so the wire might be less complex? Then I can use my own better boost guage.
Or is this still a 'massive job, different looms' answer.
