innovate LC1 wirring help
barneybrendan
Yes the serial cables connect them together, there should be enough cable to connect them without adding some, got a feeling its only one that needs to connect as the other is open for any other devices in the log chain, but i would have to re read the manual, as for the calibration cable, i will have a look at that too.
I was looking up the innovate site while talking about this in PMs and then found tricky had done the legwork :)
The random picture of wires on your leg is:
a. Red 12V supply
b. Blue Heater Ground
c. White System Ground
d. Yellow Analog out 1 (you won't use this)
e. Brown Analog out 2 (plumb this into Option 2 on the EMU, as discussed I can't recall which pin)
f. Green Analog Ground
g. Black Calibration wire
Blue on the gauge is +12v, black on the gauge is ground.
