gazzi123 Posted September 28, 2010 Share Posted September 28, 2010 Hi peeps, Any recommendations for fast road cams on a NA 97 Supra? Cheers p.s. - i know people will say its not worth doing NA up but its for a project Link to comment Share on other sites More sharing options...
Neil-NA Posted September 28, 2010 Share Posted September 28, 2010 http://ttcperformanceproducts.com/ttc-performance-2jzge-268-2268.html Thats about all i know of, sure their are others around. Link to comment Share on other sites More sharing options...
Jamesy Posted September 28, 2010 Share Posted September 28, 2010 drop Lee P a message mate - he now has his own SRD race cams with different variations depending on what you want out of them Link to comment Share on other sites More sharing options...
Neil-NA Posted September 28, 2010 Share Posted September 28, 2010 drop Lee P a message mate - he now has his own SRD race cams with different variations depending on what you want out of them For the NA ? Link to comment Share on other sites More sharing options...
Nodalmighty Posted September 28, 2010 Share Posted September 28, 2010 Just go to Piper and ask/tell them what you want. They obviously have blanks lets just hope they have enough meet for big lift (12mm+). Failing that Cat Cams make superb cams http://www.pipercams.co.uk/pipercams/www/product.php?pid=TOY2JZBP270 http://www.catcams.co.uk/acatalog/Toyota_Supra_24v_Turbo_2JZ-GTE_Engine.html Cat used to make the Rogue 11.7mm lift 3S-GTE cams (Not all profiles are listed so ask for what you need). Link to comment Share on other sites More sharing options...
Digsy Posted September 28, 2010 Share Posted September 28, 2010 (edited) What is a "fast road" cam? If you mean something that gets you high power but doesn't do it at the expense of crucifying the torque curve, then surely the stock ones probably give the best compromise? if you are looking at the camshafts only, that is. Presumably a "race" cam gets you higher power but you have to keep the engine on the boil so as not to get yourself bogged down in the low end of your ski-jump shaped power curve. Edited September 28, 2010 by Digsy (see edit history) Link to comment Share on other sites More sharing options...
gazzi123 Posted September 28, 2010 Author Share Posted September 28, 2010 What is a "fast road" cam? If you mean something that gets you high power but doesn't do it at the expense of crucifying the torque curve, then surely the stock ones probably give the best compromise? if you are looking at the camshafts only, that is. Presumably a "race" cam gets you higher power but you have to keep the engine on the boil so as not to get yourself bogged down in the low end of your ski-jump shaped power curve. A cam thats going to make noticable difference to response/power of the car. Im just trying to gather as much info as i can to see the best route to take Link to comment Share on other sites More sharing options...
gazzi123 Posted September 28, 2010 Author Share Posted September 28, 2010 Also another quick question peeps (slightly off topic) if i got a Decat are 02/lamdba sensors needed? Might sound absolutly stupid to some people - but put it down to 'your more clever than me' lol Link to comment Share on other sites More sharing options...
Jamesy Posted September 28, 2010 Share Posted September 28, 2010 yes Link to comment Share on other sites More sharing options...
Nic Posted September 28, 2010 Share Posted September 28, 2010 Also another quick question peeps (slightly off topic) if i got a Decat are 02/lamdba sensors needed? Might sound absolutly stupid to some people - but put it down to 'your more clever than me' lol The 2 oxygen sensors are located in the stock exhaust manifolds, these are essential for the running of the engine with the stock ECU. Link to comment Share on other sites More sharing options...
dr_jekyll Posted September 28, 2010 Share Posted September 28, 2010 what would be a good duration cam for a basic sub 10psi na-t . its hard to find cams foe the exhast side due to the rotor gear. everybody i have asked said they can doi an inlet can only but i cant see the point of that? would it not overload the exhaust ? Link to comment Share on other sites More sharing options...
Digsy Posted September 28, 2010 Share Posted September 28, 2010 A cam thats going to make noticable difference to response/power of the car. Im just trying to gather as much info as i can to see the best route to take Well, a noticably better response implies increased torque in the low/mid range, whereas more power is - erm - more power at the top end. Sounds like you want to beef up your torque curve right across the rev range, which is no mean feat. You could change one or the other by altering the cam timing (which is what the VVT verison does) but improving both is a big ask because I believe its been proved that the stock timing is about the best trade off between power and torque (which is what you would expect). I what guess you need as big a cams as possible without increasing the overlap so much that the idle becomes unbearable or your throttle response suffers through reversion of the exhaust gases into the plenum (which you could fix by using port throttles - another big ask). As to what the practical limits are, probably beter to ask Chris Wilson. Another approach might be to increase torque by upping the compression ratio and then figuring a way to stop it detting. Link to comment Share on other sites More sharing options...
