fullthrottle Posted September 27, 2010 Share Posted September 27, 2010 hi guys, ok i have a question that i am sure has been asked before but incase your wondering yes i have done a search and not found the answers, so here we go my supra is uk spec and at the mo its bpu i want to increase the power upto 500 -550 ish but i don't want to go single, now i no its possible ie lee p and his car, so with that in mind i was thinking of back to basic tuning polished ported head different cams hks manifold hybrid turbos then re-mapped so what do you guys think has it been done? how much will i gain? AM I WAISTING MY TIME any ideas guys. Quote Link to comment Share on other sites More sharing options...
hodge Posted September 27, 2010 Share Posted September 27, 2010 Lee.p is running big twins with a built engine. Quote Link to comment Share on other sites More sharing options...
hodge Posted September 27, 2010 Share Posted September 27, 2010 You won't make 500hp without a small single atleast. Quote Link to comment Share on other sites More sharing options...
Bailey. Posted September 27, 2010 Share Posted September 27, 2010 Mate for the things your talking about you may aswell go single, a standard clutch won't take 550hp, fueling won't either, nor will the ecu, so time u spend money on headwork and hybrids you've got enough spondies for a good single kit! Why don't you want to go single blw? Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 27, 2010 Share Posted September 27, 2010 You are asking 550hp from hybrids? i dont think thats going to happen, even if it did i suspect egt's would be massive as you would be far past there efficiency range. Dont compare to Lee P's car, that is a huge spec'd car with much bigger HKS twin turbos. Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted September 27, 2010 Share Posted September 27, 2010 Or upgrading the stock twins. I dont think the Hybrids offer much more power tbh, around 450ish with supporting mods on a J Spec. Not sure about Uk spec. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted September 27, 2010 Share Posted September 27, 2010 lees car is strictly a twin turbo... it does after all have 2 turbos... but its not a twin turbo in the way your thinking. its more like a single turbo... but 2 of them. the stock systems twin turbo setup is a different thing all together. and cant realy be upgraded past bpu. you can get hybryds but they tend to not last long and for 50bhp more max its just not worth it. Quote Link to comment Share on other sites More sharing options...
Scott Posted September 27, 2010 Share Posted September 27, 2010 (edited) You're wasting your time bud. Hybrids/cams etc etc won't get you close to your goal. Single is the only viable option really. You could get a healthy BPU, add some hybrids which would get you to about the 450 mark. Add cams and a remap might see a tiny bit more but I wouldn't expect a lot. From there your only option would be a shot of NOS. Edited September 27, 2010 by Scott (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted September 27, 2010 Share Posted September 27, 2010 (edited) hi guys, ok i have a question that i am sure has been asked before but incase your wondering yes i have done a search and not found the answers, so here we go my supra is uk spec and at the mo its bpu i want to increase the power upto 500 -550 ish but i don't want to go single, now i no its possible ie lee p and his car, so with that in mind i was thinking of back to basic tuning polished ported head different cams hks manifold hybrid turbos then re-mapped so what do you guys think has it been done? how much will i gain? AM I WAISTING MY TIME any ideas guys. You won't make 500-550hp on the stock turbos. Lee P's car is running an HKS twin turbo kit (much bigger turbos than stock), the car has a huge spec and will have cost many many £10's of thousands to build. HKS do not do a manifold for the stock turbos. Cams and aftermarket ECU will gain a little power, but the max you can expect on the stock turbos would be around 430hp (flywheel) Hybrids will max out at around 450hp (flywheel) with all the supporting mods. Polished ported head will be expensive and gains would be small. The only way to get 500-550hp would be to do a single turbo conversion. Have a read of THIS THREAD Edited September 27, 2010 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted September 27, 2010 Share Posted September 27, 2010 See here for options. Quote Link to comment Share on other sites More sharing options...
Kirk Posted September 27, 2010 Share Posted September 27, 2010 i was thinking of back to basic tuning polished ported head different cams hks manifold hybrid turbos then re-mapped Now why does this quote sound so familier but slightly reworded to suit.... In essence your attempts to push 500+ on stock twins, as already been said, will fail. Sorry but single is the only way unless you can find and mod some N1 turbos/manifolds to suit the supra. Quote Link to comment Share on other sites More sharing options...
fullthrottle Posted September 27, 2010 Author Share Posted September 27, 2010 ok so the hybrids won't work what about bigger turbos as in the the twin turbo set up from hks, the reason for me wanting to keep twins is that i want to keep it in original configuration for reliability, i don't drive this car much and i plan on keeping it for a long time ie future classic as already own a rs500 for the same reason so i hope you guys now understand why single is not an option and its also an auto so thats my one reason for not wanting single because if i have to go down that route of upgrading the gearbox then i might aswell just go all out and go for crazy power but i don't want to go that far Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 27, 2010 Share Posted September 27, 2010 (edited) ok so the hybrids won't work what about bigger turbos as in the the twin turbo set up from hks, the reason for me wanting to keep twins is that i want to keep it in original configuration for reliability, i don't drive this car much and i plan on keeping it for a long time ie future classic as already own a rs500 for the same reason so i hope you guys now understand why single is not an option and its also an auto so thats my one reason for not wanting single because if i have to go down that route of upgrading the gearbox then i might aswell just go all out and go for crazy power but i don't want to go that far Lot more to go wrong with big HKS twins and a single kit, there is two of everything, you cant compare hks twins to a stock setup in any way, you need to do some research mate, why would anyone want to run hks twins at 550bhp? the car will be laggy as hell with that setup, for big twin you need a built engine, lots of boost and a very high rev limit to get them working at there best. Edited September 27, 2010 by JamieP (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted September 27, 2010 Share Posted September 27, 2010 A single will be just as reliable as the stock TT setup, if done properly. It is impossible to keep the original configuration without spending SERIOUS money on development. There is no bolt on kit available to do what you ask. Quote Link to comment Share on other sites More sharing options...
Jamesy Posted September 27, 2010 Share Posted September 27, 2010 If u want a future classic like the rs500 then keep it 100% stock. . . . Inside, outside and engine. A decent single will be very reliable. And dont worry about the autobox it will handle around 550ftlb before you Cook it Quote Link to comment Share on other sites More sharing options...
Nic Posted September 27, 2010 Share Posted September 27, 2010 ok so the hybrids won't work what about bigger turbos as in the the twin turbo set up from hks, the reason for me wanting to keep twins is that i want to keep it in original configuration for reliability, i don't drive this car much and i plan on keeping it for a long time ie future classic as already own a rs500 for the same reason so i hope you guys now understand why single is not an option and its also an auto so thats my one reason for not wanting single because if i have to go down that route of upgrading the gearbox then i might aswell just go all out and go for crazy power but i don't want to go that far Have a look at Lee P's garage spec list, most of the parts listed are essential and have to be fitted to support the larger HKS twins, fueling, cooling, ignition, ECU mapping, drivetrain, engine rebuild, etc, etc. An HKS twin turbo kit is as far from the original configuration as you can get. A small single turbo kit will provide the power you are looking for and if quality parts are used, are professionally fitted and mapped, is no less reliable than running the stock turbos and in my own experience far more reliable. Quote Link to comment Share on other sites More sharing options...
Bailey. Posted September 27, 2010 Share Posted September 27, 2010 again, why are u so set on not going single turbo????? Quote Link to comment Share on other sites More sharing options...
fullthrottle Posted September 27, 2010 Author Share Posted September 27, 2010 ok guys well lots of info here this is why i am here asking as i certanly don't no the answers i guess my options are kinda going towards the single route have to think hard what to do:) Quote Link to comment Share on other sites More sharing options...
Nic Posted September 27, 2010 Share Posted September 27, 2010 What's your budget? A single turbo conversion will cost many many £1k's. My car was running the sort of power you are wanting, full spec HERE if interested. Quote Link to comment Share on other sites More sharing options...
Digsy Posted September 28, 2010 Share Posted September 28, 2010 ok so the hybrids won't work what about bigger turbos as in the the twin turbo set up from hks, the reason for me wanting to keep twins is that i want to keep it in original configuration for reliability, i don't drive this car much and i plan on keeping it for a long time ie future classic as already own a rs500 for the same reason so i hope you guys now understand why single is not an option and its also an auto so thats my one reason for not wanting single because if i have to go down that route of upgrading the gearbox then i might aswell just go all out and go for crazy power but i don't want to go that far You can't take an engine that was designed to deliver 320hp, do a 56% power hike and still make any claims about its reliability The 2JZ has only ever "proved" its reliability in one form, and that is stock. Yes, plenty of people on here have modded engines turning out high power, and no, they very rarely appear to go bang. But they may not drive the way you are going to drive. Perhaps they only spend 1% of their total driving time above peak torque. Perhaps they do the occasional full throttle blat at Santapod. Maybe there are several people who use these cars as a daily drive and are up and down the speed / load range all the time. Those are the people to try to get ideas about reliability of modded engines from, but if you are planning to keep this car for a long time, you would need to find someone who has already kept theirs for a long time without any issues. I'm not anti-modding, but working in the motor industry, reliability has a rather special meaning to me. No disrespect to any of the tuners on here but an industry standard durability test would probably leave 99% of modded engines in little pieces on the dyno room floor (and walls). If you want to have a future classic in your garage in ten years time, surely its best kept as Toyota intended it? Quote Link to comment Share on other sites More sharing options...
