sams Posted September 27, 2010 Share Posted September 27, 2010 Im hoping someone Can help; I dont know whats the matter with the laptop, i turned it on all seemed fine, got the normal windows scroll bar then when it come to load the user login bit nothing happens, it all blank black screen It vista btw Appart from fixing with fire or hammer im out of ideas Quote Link to comment Share on other sites More sharing options...
Scott Posted September 27, 2010 Share Posted September 27, 2010 Reboot the lappy pressing F8 repeatedly. You will get options, select Safe mode with network. See if that lets you in. If it does you can try a restore. Quote Link to comment Share on other sites More sharing options...
sams Posted September 27, 2010 Author Share Posted September 27, 2010 Same proplem in safe mode, but i noticed there more options than normal in the boot menu, , In order; Repair your computor Safe mode Safe mode with networking Safe mode with command prompt Enable boot logging Enable low-resolution video (640x480) Last known good configuration (advanced) Directory services restore mode Debigging mode Disable automatic restart on sustem failure Disable driver signature enforcement Start windows normally These are the options im presented with, as said safe mode does the same, and the last good configuration does the same Quote Link to comment Share on other sites More sharing options...
sams Posted September 27, 2010 Author Share Posted September 27, 2010 Is there a way to completely wipe the computer And reinstall key componants Quote Link to comment Share on other sites More sharing options...
Scott Posted September 27, 2010 Share Posted September 27, 2010 Last good configuration has probably fooked your install, it did to me. Do you have a vista install disc? You can repair the startup via that. Quote Link to comment Share on other sites More sharing options...
Scott Posted September 27, 2010 Share Posted September 27, 2010 Is there a way to completely wipe the computer And reinstall key componants With the install disc, yes. Everything goes bye bye though, photos, music, the works. Quote Link to comment Share on other sites More sharing options...
sams Posted September 27, 2010 Author Share Posted September 27, 2010 Last good configuration has probably fooked your install, it did to me. Do you have a vista install disc? You can repair the startup via that. No the laptop was a return, the cpu over heated ages ago, and i brought it from acer as a repaired comp been alright till last few days when i got a avg notice two trojans were in system 32 files and could not me removed Quote Link to comment Share on other sites More sharing options...
sams Posted September 27, 2010 Author Share Posted September 27, 2010 With the install disc, yes. Everything goes bye bye though, photos, music, the works. That what i want to do lol Quote Link to comment Share on other sites More sharing options...
Scott Posted September 27, 2010 Share Posted September 27, 2010 Need to get windows bud. I would recommend windows 7. Quote Link to comment Share on other sites More sharing options...
sams Posted September 27, 2010 Author Share Posted September 27, 2010 I assume i would have to buy a disk to do it or whether it vista ot windows 7 Quote Link to comment Share on other sites More sharing options...
Scott Posted September 27, 2010 Share Posted September 27, 2010 Legally yes Unless there is a hidden partition on the laptop, in which case all you would need is a recovery disc from the manufacturer. Quote Link to comment Share on other sites More sharing options...
Smallshinyant Posted September 27, 2010 Share Posted September 27, 2010 You might be lucky with a self recovery option. When the computer boots and you get the BIOS post screen. Is there an option that says something like press F10 for recovery . What make is it? Quote Link to comment Share on other sites More sharing options...
edinlexusV8 Posted September 27, 2010 Share Posted September 27, 2010 I had exactly the same problem with my partner's acer, it was an old laptop so gave up after a few tries and got her a new Sony in cherry red. She loves it to bits ... end of the problem for me! Quote Link to comment Share on other sites More sharing options...
Scott Posted September 27, 2010 Share Posted September 27, 2010 Can I have the old Acer? Quote Link to comment Share on other sites More sharing options...
MaveriK Posted September 27, 2010 Share Posted September 27, 2010 Try F8 and then safe mode command prompt only. If that lets you get in then reply back, we can then edit your registry to stop anything starting that may cause the hang Quote Link to comment Share on other sites More sharing options...
sams Posted September 27, 2010 Author Share Posted September 27, 2010 I have a vista disk how do i go about loading and restarting the comp, safe mode does not work for any the options Quote Link to comment Share on other sites More sharing options...
Scott Posted September 28, 2010 Share Posted September 28, 2010 I'm curious, why are you posting the same thing? Quote Link to comment Share on other sites More sharing options...
Smallshinyant Posted September 28, 2010 Share Posted September 28, 2010 You need it to boot of the CD. Stick the disk in and should ask "Press and key to boot from CD" you will want to do that. If it does not ask you that, you will want to check the boot options in the BIOS. Quote Link to comment Share on other sites More sharing options...
