Guest blueangel Posted September 27, 2010 Share Posted September 27, 2010 Ive connected the laptop up to the tv via one of those cables with the 2 screws at the sides :rolleyes:dont know what its called the picture comes up but i have to make do with the sound on the laptop it wont come throu the tv, what am i doing wrong guys Quote Link to comment Share on other sites More sharing options...
Guest high tower Posted September 27, 2010 Share Posted September 27, 2010 its best to use the 3 plugs yellow white and red because thats got the sound and plays good or plug the three to a scart like me.... Quote Link to comment Share on other sites More sharing options...
Stonkin Posted September 27, 2010 Share Posted September 27, 2010 Surely that cable will only send videao signal not audio to? If your laptop is old and has a pcmcia socket you can get a card that will do videao and audio. Or you could always get the cable that will plug into the headphone socket on laptop and split to the red and white audio connectors to put into the tele or amplifier. Quote Link to comment Share on other sites More sharing options...
JustGav Posted September 27, 2010 Share Posted September 27, 2010 its best to use the 3 plugs yellow white and red because thats got the sound and plays good or plug the three to a scart like me.... You are kidding right? composite quality is LOUSY! Okay, the VGA connector (blue) or DVI connector (white) doesn't support audio, you would either have to use a seperate audio feed via either optical or analouge (white/red headphone style) or use an HDMI with audio Quote Link to comment Share on other sites More sharing options...
Guest blueangel Posted September 27, 2010 Share Posted September 27, 2010 the laptop is an old dell Quote Link to comment Share on other sites More sharing options...
monsween Posted September 27, 2010 Share Posted September 27, 2010 You are kidding right? composite quality is LOUSY! Okay, the VGA connector (blue) or DVI connector (white) doesn't support audio, you would either have to use a seperate audio feed via either optical or analouge (white/red headphone style) or use an HDMI with audio What he said! See if your TV has a 3.5mm audio INPUT line (not the headphone jack) Then use a standard 3.5mm to 3.5mm jack (headphone sockets) from the laptop headphone port to the tv Quote Link to comment Share on other sites More sharing options...
JustGav Posted September 27, 2010 Share Posted September 27, 2010 the laptop is an old dell http://www.ebuyer.com/product/21913 + http://www.maplin.co.uk/Module.aspx?ModuleNo=35928&OrderCode=L46AJ Quote Link to comment Share on other sites More sharing options...
Smallshinyant Posted September 27, 2010 Share Posted September 27, 2010 Your best chance is that your plasma has a 3.5mm head phone style jack to input sound(if its suitable to use at the same time as VGA it will be near it. So if you can get a 3.5mm from your headphone sockt on laptop to 3.5mm on the TV cable you will probably find that may do the job. Quote Link to comment Share on other sites More sharing options...
monsween Posted September 27, 2010 Share Posted September 27, 2010 http://www.ebuyer.com/product/21913 + http://www.maplin.co.uk/Module.aspx?ModuleNo=35928&OrderCode=L46AJ Thats REALLY expensive for that headphone to phone lead, you can pick them up for half that price Quote Link to comment Share on other sites More sharing options...
JustGav Posted September 27, 2010 Share Posted September 27, 2010 Thats REALLY expensive for that headphone to phone lead, you can pick them up for half that price Yup, it's maplins.... didn't have time to look for a cheaper supplier (maplins is like halfrauds and pcworld.... only get seen in them late on a sunday afternoon when everything else is closed ) Quote Link to comment Share on other sites More sharing options...
monsween Posted September 27, 2010 Share Posted September 27, 2010 Ebay is your friend for one of those cables. Plus maplin does do cheaper versions http://www.maplin.co.uk/Module.aspx?ModuleNo=31700 Quote Link to comment Share on other sites More sharing options...
