Marc's Facelift Aerotop TT6 Project
marc_p
  • Replies 151
  • 1 year later...
Ok, huge update and I shall be updating with pics when I get home but the parts that are currently in the process of being fitted are:
Engine:
-Borg Warner S366 Turbo w/ polished housing
-Whifbitz Twin Wastegate Manifold
-2x Turbosmart 40mm Wastgates
-4" Alloy intake pipe
-Goodridge braided oil feed and drain lines
-Billet alluminium oil drain flanges
-4" Kakimoto Exhaust System with 4.5" exit
-Polished Rocker Covers
-Whifbitz screamer pipes
-K&N Air Filter
-K&N ICV Filter
-Whifbitz 3.5" v-band downpipe
-Gates Racing Cambelt
-Garage Whifbitz Magnetic Sump Plug
-Garage Whifbitz Billet cambelt tensioner bracket
-D1 Spec oil catch tank
-Unorthodox Racing Water Pump Pulley
-Unorthodox Racing Fan Pulley
-Unorthodox Racing Alternator Pulley
-Garage Whifbitz Idler Pulley
-New Toyota Cambelt Tensioner
-New Toyota Water pump
-New Toyota Oil pump
Cooling:
-SRD Twin Electric fans
Fueling:
-Bosch 044 Fuel Pump
-Bosch in-tank adapter
-Sard 800cc Injectors
-Aeromotive Fuel Pressure Regulator
-Garage Whifbitz Fuel Pulsation Dampner removal hose
-Garage Whifbitz FPR Fitting Kit
-New Toyota Fuel Filter
Engine Management:
-Motec M600 ECU
-Launch Control Programmed Through Motec
-Traction Control Programmed Through Motec
-Anti-Lag Programmed through Motec
-Secondary Lamba O2 sensor programmed through Motec
-Full Throttle Up-Shift Programmed through Motec
Chassis:
-Replacing EVERY bush, with SuperPro for the Suspension and Diff bushes, R2 racing for the steering rack and TRD for the engine mounts.
Braking:
- New Willwood front calipers and pads
- Wilwood adapter brackets for above
- UK Spec rear callipers
- Goodridge brake lines all round
- Brembo drilled disks
Then it's going for mapping, then to Chris Wilson to set the suspension up, then to get resprayed back to RSP, then off for an MOT.................Got my work cut out :D
OMG your number plate!! (the black car)Noticed its very similar to mine...
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=171736&d=1372438220
The spec looks good mate, noticed your in yorkshire so you will have to take me for a ride once its done :-)
Ha ha, yeah, very similar, the plate is now sat on a Toyota Landcruiser, not quite as fitting really:D
Also, yeah I'm over Harrogate way but more than welcome to give you a ride out in it once done :)
Just read all through this thread Marc, lovely car you have there, I might have missed it, but have you re-painted her the original RSP colour yet or is that still on the to do list?
Hopefully getting it sprayed over winter back to RSP once all the work is done as the paint may get some scratches in it whilst I'm pottering away on it.
Ah that's awesome mate, only other colour I really love on the supra is RSP other than Black, should look amazing when its finished :)
  • 4 weeks later...
Ok, I'll try and update this today with some pics but so far the below is on the car:
Engine:
-K&N Air Filter
-K&N ICV Filter
-Power House Racing Cam Covers
-Power House Racing Breather kit
Fueling:
I have changed a few things from the initial spec, the D1 catch tank has been dropped in favor of the full Power House Racing breather system, the Wilwoods have been dropped and I have now gone with UK spec brakes, so the current spec list once finished is looking like so:
Engine
2JZ-GTE Engine
Super Spark Coilpacks
Goodridge braided oil feed line
K&N Air Filter
K&N ICV Filter
Carbon Fibre Fuse Box cover
TRD Oil Cap
Powerhouse Racing Modified Cam Covers
Powerhouse Racing Breather System
Fuelling
Bosch 044 Fuel Pump
Management
Motec M600 ECU
HKS EVC-S Boost Controller
Apexi Turbo Timer
AEM AFR Gauge
TT6 Loom from donor car
ABS and TC system from donor car
Cooling
AFR Dualcore intercooler
Koyorad Radiator
APR Carbon Fibre Cooling Plate
3.5" Alloy intercooler piping
Whifbitz 72 celcius thermostat
Drivetrain
A161 6 Speed Getrag Gearbox
TRD Gearbox Mount
TRD Clutch Line
RPS Cyn-R-G Flywheel
RPS Streetmax Clutch
AP Engineering Shifter Bushes
A03B Limited Slip Differential
Hubs, driveshafts, etc taken from TT6 donor car
Manual gearbox tunnel taken from TT6 Donor Car
Chassis
18" Enkei Nel Classe wheels(8.5J Front 11j Rear)
Rear Tire: 295/35/18 Brigestone Potenza's
Front Tire: 235/35/18 Falken 452's
Tein Flex Coilovers
Tein Electronic Damping Force Control
Super Pro Lower Control Arm Bushes, front and rear, inner and outer
Super Pro Upper Control Arm Bushes, front and rear inner and outer
Super Pro Anti Roll Bar Bushes front and rear
Super Pro Subframe Bushes front and rear
Super Pro Steering Rack Bushes
Subframes taken from TT6 donor car
Bodywork
TRD Carbon Fibre Wing (Probably going back to stock)
Interior
Gear stick and handbrake gaiters trimmed in black leather with blue stiching
Sony double din headunit
Boston Audio speakers in place of standard speakers
Dash and clocks taken from Facelift TT6 Donor car
Braking
UK Spec brakes
Brembo Disks
CW pads
Goodridge braided lines
New OEM Parts
Crank Pulley
Cambelt Tensioner
Water pump
Oil pump
Exhaust Gasket
Inlet gaskets
Fuel Filter
You will notice there is a lot of stuff from the donor car there, it's because I wanted it as close as it could possibly be to having a factory TT6 Facelift Aerotop, so it had pretty much a full shell swap with my (undamaged) facelift hardtop TT6, the only things that haven't been changed from the TT6 are the carpets, headlining and bodypanels :D, which makes life a lot easier when working on it as everything is as it should be on a TT :).
Ok Here we go, a VERY quick summary in photos :D:
Car all ready to get started on:
First stages of stripping down:
Cleaning, painting and fitting new pumps etc:
Manifold On:
Slowly getting put back together:
Getting there:
Then deciding to change FPR and breather set up had it looking like this last night:
Just read through this today. Great work dude. Looking forward to seeing the finished job. Lovely looking Supra. :cool:
And I've just seen what my photo's look like when they are on a bigger screen than my phone, dear god they are horrible!:D
But thanks :thumbs:
  • 3 months later...
  • 1 year later...
