adnanshah247 Posted September 27, 2010 Share Posted September 27, 2010 Right im after a phone cable that is RJ11 on 1 side and the second side to be RJ10. http://www.your-connect.ch/news-detail.asp?newsid=184 If you click that link you can scroll down and see an image of the rj10 and rj11 ends next to one another. I either need a striaght cable with wires ends either side or a rj11 to rj10 convertor (vice versa). please help because i have gone absolutely mental trying to find this wire. I can crimp and make it if need be so if somebody can find me the exact wiring diagram that will do great as well! Thanks lads! Quote Link to comment Share on other sites More sharing options...
Sandy-m2 Posted September 27, 2010 Share Posted September 27, 2010 Will the socket that is rj11 not just take an rj10 plug, I have rj11's plugged into rj45's? S Quote Link to comment Share on other sites More sharing options...
Scott Posted September 27, 2010 Share Posted September 27, 2010 Should plug straight in mate. RJ10's on both sides. Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted September 27, 2010 Author Share Posted September 27, 2010 Should plug straight in mate. RJ10's on both sides. yes but the cable stays a lil loose and its needed for these wireless headsets, second it moves it kills all communication on the headsets and then you need to sit and mess about with it, real PITA! i need a secure solid connection in between. Quote Link to comment Share on other sites More sharing options...
Scott Posted September 27, 2010 Share Posted September 27, 2010 Is the socket broken? The little clip should hold it in place? Or is the clip broken on the cable? Regardless, it is only 4 wires. If they are red blue green orange then you just wire the other side red blue green orange so you can get the connections done very easily. Quote Link to comment Share on other sites More sharing options...
comorin219 Posted September 27, 2010 Share Posted September 27, 2010 Have you tried Cambridge Electronic Industries think they make gender changer cables etc Quote Link to comment Share on other sites More sharing options...
JustGav Posted September 27, 2010 Share Posted September 27, 2010 RJ11 + Epoxy Resin = Not moving for sh.... Quote Link to comment Share on other sites More sharing options...
JustGav Posted September 27, 2010 Share Posted September 27, 2010 ywireless headsets.......... i need a secure solid connection in between. Hmmm, I thought the clue was in the phrase Wireless Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted September 27, 2010 Author Share Posted September 27, 2010 Hmmm, I thought the clue was in the phrase Wireless lol, the headset is wirless but its docking station needs to connect to the phone. i need about 20 cables because each and every phone has the same problem and im getting sick of it. the connection to the phone is RJ11 and the connection to the docking station is RJ10. Quote Link to comment Share on other sites More sharing options...
Ric Posted September 27, 2010 Share Posted September 27, 2010 i have thousands around you are looking for a telephone handset cable as for making the cable, its straight through, same on both ends Quote Link to comment Share on other sites More sharing options...
