Evo Rad Bleeding
Suprab1
Lads i need a little help. i was checking the Evo for oil & water & the water in the rad looked a little low so i topped it up with a drop of coolant. Now though the water temp gauge reads zero but the fan is kicking in to cool the rad.
The top & bottom rad pipes are hot & i'm also getting hot air inside the car.
Could this just be an air lock? If so how do i bleed it?
Thanks Rab.
