Supra Parts clearout
mrgee2jz
Hi guys, ive been going through my goodies and have decided to sell a few bits and make some room ;)
Parts list are as follows:
1. ARP Main Studs (new in box) £90
2. Manual TT ECU £70
3. Manual N/A ECU £30
4. Custom TT Inlet manifold for fitting 2JZ GTE into tight engine bay £100
6. TT oil Pump £30
7. Green Stuff front pads for UK 4 pots. 50% worn but nice and straight, £15
8. Rear 2 pot pads 50% worn £5
9. Radio surround cage holder £10
10. TT top rad pipe on that bolts to head, power coated in black with both temp sensors £30
12. 2jZ engine mounts £40
13. Boot carpet £15
14. Supra ignition barrel with original KEY £25
15. Boot trims £5 each
17. Indicator and wiper stauk £10
18. Sump upper part N/a £10 TT £20
20. Drivers wing in white £50
22. N/A manual RAD £30
23. passenger door glass £30
24. Inlet air duct cover £5
25. exhaust cover prop guard £5
26. door handle n/s o/s £5 each
27. passenger window regulator £15
28. Rear bumper (white) £30
29. Crank pulley for na or tt £65
31. alternator £30
32. Drivers OEM side skirt SILVER (need a passenger one!) £80
33. AUTO TT ECU £60
34. AUTO TT TRACTION ECU £25
37. Blitz Dump Valve (bolts to TT setup with bracket) £60
38. rad ducting before rad in bumper £5
39. starter motor N/A or TT £45
40. 1JZ bottom end, (block, pistons, crank) £100
41. 2 Piece Brake disks/rotors for UK 4 pot supra calipers (used for about 50 miles before me but i
dont need them now) Like new £100
  • Replies 76
Intrested in rear bumper - what condition it in mate?
I have rear spats are they easily taken off and put on?
Also if you have the drivers + passenger glass ill take them both?
Cheers
Hi there, the bumper will need spraying as its been in the garden for a while, yes as long as they are not glued on, but you shouldnt need to remove them.
i have passenger glass £30
Great if you can PM me your address as ill pick it up mate as its glass and pay cash on collection if thats ok?
Also if i have the bumper a machine mop/polish would it be ok or is it beyong repair in that way and deffo needs respray?
(if its ok to pick up glass next week sometime + bumper still there isit ok if i take a look)?
Cheers
Cheers
Yes thats perfect, pm'ed you my add,
it will prob clean up but nicely,
yes just let me know when and ill be here:)
