running lean
TT Paul
after taking car to AFR they put probe in the exhaust and was shown to be lean told that should read around 1 but idle was 109 apply throttle and was 1.17..
and also have a profec b 2 boost controller normaly reads -50 on idle but on way back home it started at -67 then went as high as
-75 on idle are these related any info would help as a little lost thanks
CAR SPEC jspec tt full bpu auto 1.1bar boost
Edited by TT Paul (see edit history)
checked the map sensor and swapped it voltages on both were similar the only thing was no voltage on brown wire guess its the earth also cleaned out sensor to stock fuel reg, went for a drive seemed ok
did have f/ code 31 but even when i swapped over map sensors and cleared codes it didn't come back even with old sensor.. need to check AFRs when i get gauge
but profec b boost gauge you to show -50 on idle now shows -65 to -70 is that a boost leak checked what i can until i pressurise system next wk
UPDATE checked o2 sensor voltage when warm 0.1 so guess thats knackered getting a new one, tried swapping ecu and removed FCD no difference and couldn't find any boost leaks could this be electrical maybe faulty boost gauge getting abit lost until i replace o2 sensor but can that cause what is happedning
Update after several new parts went for a drive afr gauge reading ok then got home stopped engine restarted went straight off gauge too lean unplugged fcd restarted fine again appears fcd was breaking down causing problem thing is i unplugged this before made no difference then just went
and thanks to afr for advise
