TT Paul Posted September 26, 2010 Share Posted September 26, 2010 (edited) after taking car to AFR they put probe in the exhaust and was shown to be lean told that should read around 1 but idle was 109 apply throttle and was 1.17.. and also have a profec b 2 boost controller normaly reads -50 on idle but on way back home it started at -67 then went as high as -75 on idle are these related any info would help as a little lost thanks CAR SPEC jspec tt full bpu auto 1.1bar boost Edited September 26, 2010 by TT Paul (see edit history) Quote Link to comment Share on other sites More sharing options...
Muffleman Posted September 26, 2010 Share Posted September 26, 2010 We found a couple of bits but do those checks I told you to do mate then pop back when you get a chance, dyno days are very quickfire so we couldn't spend long on it as I was doing power runs til 5pm ! But we'll sort it out mate Quote Link to comment Share on other sites More sharing options...
Nic Posted September 26, 2010 Share Posted September 26, 2010 What's the spec of the car? What boost are you running? Did AFR not suggest what the problem may be? Quote Link to comment Share on other sites More sharing options...
Muffleman Posted September 26, 2010 Share Posted September 26, 2010 Yeah gave a few suggestions but really don't get spend a lot of time on an open day. Seems lean outside of O2 feedback so maybe fpr, gave Wiggy another MAP sensor FOC to try etc but really didn't have much time. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted September 26, 2010 Author Share Posted September 26, 2010 (edited) will be trying what you said matt just see if any other things i can check also bought a AEM afr gauge just waiting for it to turn up. Edited September 26, 2010 by TT Paul (see edit history) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 26, 2010 Share Posted September 26, 2010 An AFR gauge will give you much more definitive view on what going on regarding fueling, so you can start to access and diagnose any problem's. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted September 26, 2010 Author Share Posted September 26, 2010 An AFR gauge will give you much more definitive view on what going on regarding fueling, so you can start to access and diagnose any problem's. as you said mate the gauge will help im gonna check what i can hoses map sensor voltages etc go from there Quote Link to comment Share on other sites More sharing options...
TT Paul Posted September 26, 2010 Author Share Posted September 26, 2010 checked the map sensor and swapped it voltages on both were similar the only thing was no voltage on brown wire guess its the earth also cleaned out sensor to stock fuel reg, went for a drive seemed ok did have f/ code 31 but even when i swapped over map sensors and cleared codes it didn't come back even with old sensor.. need to check AFRs when i get gauge but profec b boost gauge you to show -50 on idle now shows -65 to -70 is that a boost leak checked what i can until i pressurise system next wk Quote Link to comment Share on other sites More sharing options...
TT Paul Posted September 27, 2010 Author Share Posted September 27, 2010 UPDATE checked o2 sensor voltage when warm 0.1 so guess thats knackered getting a new one, tried swapping ecu and removed FCD no difference and couldn't find any boost leaks could this be electrical maybe faulty boost gauge getting abit lost until i replace o2 sensor but can that cause what is happedning Quote Link to comment Share on other sites More sharing options...
Nic Posted September 27, 2010 Share Posted September 27, 2010 A faulty O2 sensor would make the car run rich at low rpms, it wouldn't be the cause of running lean when on boost. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted September 27, 2010 Author Share Posted September 27, 2010 A faulty O2 sensor would make the car run rich at low rpms, it wouldn't be the cause of running lean when on boost. its running lean at idle etc Quote Link to comment Share on other sites More sharing options...
TT Paul Posted October 2, 2010 Author Share Posted October 2, 2010 Update after several new parts went for a drive afr gauge reading ok then got home stopped engine restarted went straight off gauge too lean unplugged fcd restarted fine again appears fcd was breaking down causing problem thing is i unplugged this before made no difference then just went and thanks to afr for advise Quote Link to comment Share on other sites More sharing options...
