ilicos Posted September 24, 2010 Share Posted September 24, 2010 I have been offered the above for £1350 with all ancillaries and Turbos and was wondering if I could use the gearbox as its the tiptronic box. Also, would I need to get a Supra TT loom? Engine has 75k on the clock so wanted some opinions. I didn't think that the Lexus came with a TT engine so could this have been an Aristo re-badged or engine swap? Cheers, Ilias Link to comment Share on other sites More sharing options...
adnanshah247 Posted September 24, 2010 Share Posted September 24, 2010 hey bud, the sump on the engine will need to be changed and yes you will need a supra TT loom. as far as mileage goes the 2jz is a strong very well built engine, ensure that it has been maintained and you got yourself a good deal. i presume the engine you have is from a MK2 Aristo? the V300 i think its called. Link to comment Share on other sites More sharing options...
ilicos Posted September 24, 2010 Author Share Posted September 24, 2010 Hi Adnan, I was aware of the sump issue but the loom was my biggest query along with if I could use the gearbox. I like the thought of the tiptronic over a standard auto box Link to comment Share on other sites More sharing options...
Awisto Posted September 24, 2010 Share Posted September 24, 2010 You'll need the ECU from the Aristo aswell. Non VVTi supra loom will be useless. Link to comment Share on other sites More sharing options...
ilicos Posted September 24, 2010 Author Share Posted September 24, 2010 What I don't want is to buy it and be stuck with the engine and not be able to use it because I don't have a loom. Again, if anyone knows if I can use the gear box then I would be grateful if you could let me know. Link to comment Share on other sites More sharing options...
Nic Posted September 24, 2010 Share Posted September 24, 2010 You can buy complete new looms from Toyota, not cheap though. I used an Aristo VVTi 2JZ-GTE long block on mine, with a non-VVTi 2JZ-GTE Supra head and non-VVTi 2JZ-GTE loom on mine, the only difference electronics wise was the oil pressure sensor plug was different. Link to comment Share on other sites More sharing options...
Awisto Posted September 24, 2010 Share Posted September 24, 2010 The gearbox is controlled by the main ECU, so you will need a VVTi loom and VVTi ECU Link to comment Share on other sites More sharing options...
michel lane Posted September 25, 2010 Share Posted September 25, 2010 if you put an after market ecu on the car you can run it on a standard loom. but you need to swap the autobox with you own. talk to ryan about his, he is the man who can advise you better. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted September 25, 2010 Share Posted September 25, 2010 How much will a VVTi auto loom cost from Toyota? Link to comment Share on other sites More sharing options...
