Guest Rottweiler Posted September 24, 2010 Share Posted September 24, 2010 Does anybody know of somewhere in the Norfolk area where I can take my Supra for a diagnostic check? Two people have let me down in the last fortnight by not turning up. The car`s just sitting there doing nothing and ist been a waste of two weeks holiday as I daren`t take it out how it is. One day it runs fine, the next it over fuels and wont tickover. Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 24, 2010 Share Posted September 24, 2010 You can check the diagonostic codes yourself and post the results here. Sounds like O" sensor faulty. Quote Link to comment Share on other sites More sharing options...
TopgunTT Posted September 24, 2010 Share Posted September 24, 2010 Do toyota do some kind of fault finder that you can plug in and tell you the code, Just keep it in the car then. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 24, 2010 Share Posted September 24, 2010 (edited) You can check the diagonostic codes yourself and post the results here. Sounds like O" sensor faulty. See instructions HERE First of all though I would try resetting the ECU, remove a battery terminal for a couple of minutes. After you have reset it the car may not idle well, drive for a few miles and it should sort itself out. BTW what car is it NA or TT? Edited September 24, 2010 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
