stock j.spec overboosting
BABZ988
hi all
this week i've fitted my G'reddy FMIC and since the car is overboosting
From stock .85b now it is now boosting to 1.1b
and i still have my 1st & 2nd cat
now the car is struggling when that happen
Is it usually that the boost increase that much just with a FMIC???
Will it be ok if i install my uprated fuel pump ??
Thanks
It isn't a good idea to run that sort of boost when you have the cats in place. It will create a lot of heat and you will run the risk of dangerous gas temps.
I would recommend fitting an EGT gauge to see what you are getting.
What do you mean the car is struggling? Is it hesitating? Misfiring?
yes , i know that it is dangerous to run that sort of boost on a full stock car, and i know the risk , that's why since i sort that i don't go WOT
but i've never heard of boost increase with just an FMIC installed that's why i'm surprised !
it's more 1.02 than 1.1b
i have a profec b boost controller installed on the FPR vacuum line but i've just installed the controller too read the boost ( solenoid hoses are not plumb ) that's where i read the boost
the car is hesitating on 2nd turbo only
i'll find out for the EGT gauge
i've my FMIC fitted because i'm doing a BPU but didn't had time to fit all parts
and good point why don't i hit fuel cut ??
i didn't install FCD yet !!
it maybe because you say that i must push the P° for 1sec or more!! what i dont do !!
the thing is; before; every thing was perfect
i had some rough idle issue but all runing good
if i don't floor it all run perfectly
i only have this happpening when i go WOT, and at full boost
and yes that hesitation is worring me ,
i think i should complete my BPU upgrade and see what's happening
Regarding the hesistation on the transistion to the 2nd turbo; that could sound like something strange in the vacuum system, VSVs or EGCV or EBV. But a bit strange since you havent messed with anything in the vacuum system (or have you?)
Take a look here for A LOT of info on the vacuum system and troubleshooting it:
http://www.97supraturbo.com/FAQ.html
I have neved installed a boost controller (I just have a restriction in the exhaust), but you might want to try and remove that to eliminate that as a possible issue.
Ahh, the hesitation will be you hitting fuel cut. When you say hesitation, is it like hitting a brick wall and just doesn't want to go?
If that is the case, it is only the overboosting & temps you need worry about. If you get a 1st de-cat & restrictor ring, or at least an EGT gauge, that will help you out no end.
