add heywood Posted September 21, 2010 Share Posted September 21, 2010 So the car is being booked in next month for the head gasket to be replaced and the HKS 264's to be put in. I said I would supply engine parts. Just want confirmation on bits I need to replace... OEM Head gasket (obviously lol) ARP stud kit exhaust gasket intake gasket Anything else? such as cam seal gaskets, cam cover gaskets etc... Would it be easy to do valve stem seals with the head off also? Also do Toyota do a full head set (eg all gaskets needed for head removal)? Where would be the best place to get these from? Cheers Add Quote Link to comment Share on other sites More sharing options...
hodge Posted September 21, 2010 Share Posted September 21, 2010 Cam oil seals Valve stem oil seals Intake and exhaust gaskets Top water neck gasket Cam cover gaskets Cam cover breather pipes Yeah Toyota do a full engine gasket kit. Not sure if they do a head gasket kit though. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 21, 2010 Share Posted September 21, 2010 Yes Toyota do a complete gasket/seal kit that includes everything you'll need. 04112-46056 Valve Grind Kit http://img183.imageshack.us/img183/9239/picture1uo5.png Quote Link to comment Share on other sites More sharing options...
Nic Posted September 21, 2010 Share Posted September 21, 2010 Yeah Toyota do a full engine gasket kit. Not sure if they do a head gasket kit though. Yeah they do a head kit and a complete engine kit. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted September 21, 2010 Share Posted September 21, 2010 also add water pump and thermo to your list mate, and seals are easy done and recommended if head is off Quote Link to comment Share on other sites More sharing options...
hodge Posted September 21, 2010 Share Posted September 21, 2010 also add water pump and thermo to your list mate, and seals are easy done and recommended if head is off Yep a water pump is a must really if you have it all apart anyway. Quote Link to comment Share on other sites More sharing options...
hodge Posted September 21, 2010 Share Posted September 21, 2010 I got a full engine gasket kit and a genuine Toyota water pump from a friend of mine at Toyota for 320 quid I think. Quote Link to comment Share on other sites More sharing options...
add heywood Posted September 22, 2010 Author Share Posted September 22, 2010 thanks for your replies everyone. Where would be cheapest to get the said items? Quote Link to comment Share on other sites More sharing options...
TLicense Posted September 22, 2010 Share Posted September 22, 2010 I got a full engine gasket kit and a genuine Toyota water pump from a friend of mine at Toyota for 320 quid I think. I paid £180 for the gasket kit two weeks ago at Inchcape. Is the pump really that expensive? Quote Link to comment Share on other sites More sharing options...
add heywood Posted September 22, 2010 Author Share Posted September 22, 2010 Yes Toyota do a complete gasket/seal kit that includes everything you'll need. 04112-46056 Valve Grind Kit Been searching but can't tell if 04112-46056 comes with valve stem seals as a part of the kit... Does anyone know the contents of it? Quote Link to comment Share on other sites More sharing options...
Nic Posted September 22, 2010 Share Posted September 22, 2010 (edited) Been searching but can't tell if 04112-46056 comes with valve stem seals as a part of the kit... Does anyone know the contents of it? Yes includes all the valve stem seals. It basically includes all the seals and gaskets needed to remove the head and do the stem seals, head gasket, intake gasket, exhaust gaskets, cam seals, stem seals, various other gaskets and seals, etc. Everything shown on the pic. Edited September 22, 2010 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
add heywood Posted September 22, 2010 Author Share Posted September 22, 2010 Yes includes all the valve stem seals. It basically includes all the seals and gaskets needed to remove the head and do the stem seals, head gasket, intake gasket, exhaust gaskets, cam seals, stem seals, various other gaskets and seals, etc. Everything shown on the pic. Cheers Nic your a legend Quote Link to comment Share on other sites More sharing options...
hodge Posted September 22, 2010 Share Posted September 22, 2010 Might have been 220 quid. I'll check. But those were genuine Toyota parts. Quote Link to comment Share on other sites More sharing options...
add heywood Posted September 22, 2010 Author Share Posted September 22, 2010 £320 sounds about right from looking around at prices, water pump about £130 Quote Link to comment Share on other sites More sharing options...
