Ricky49 Posted October 16, 2010 Share Posted October 16, 2010 Looking good Jay. Link to comment Share on other sites More sharing options...
Kirk Posted October 17, 2010 Share Posted October 17, 2010 You could of atleast tidied the rails up before fitting them. Paint doesnt weigh much you know Link to comment Share on other sites More sharing options...
jevansio Posted October 17, 2010 Author Share Posted October 17, 2010 m_life said: You could of atleast tidied the rails up before fitting them. Paint doesnt weigh much you know I'm waiting until I do the drivers side, once done I'll remove an extra bits that aren't needed (for instance, those bits at the front are far too high and there is a lot of wasted material), then I will spray the lot black Link to comment Share on other sites More sharing options...
jevansio Posted October 30, 2010 Author Share Posted October 30, 2010 Got round to spraying the frames black, looks a lot better IMHO I also decided to fit the TRD transmission mount & AP gearshift bushings. My gearshift was feeling a bit sloppy & I hoped this would help tighten things up. Upon removing the cradle though I found the cause for my sloppy gearstick, the oem bushes had completely disintegrated and just fell out The new solid AP should sort that right out. Also as I was taking this out I took the opportunity to measure up a facelift gearstick against a prefacelift my good mate Hodge gave me . As expected the old one is shorter, so that's going back in when it all goes back together Overall the shifting feel should be massively improved Link to comment Share on other sites More sharing options...
JamieP Posted October 30, 2010 Share Posted October 30, 2010 You should get them seat mounts copied, id buy a set off you. Link to comment Share on other sites More sharing options...
jevansio Posted October 30, 2010 Author Share Posted October 30, 2010 JamieP said: You should get them seat mounts copied, id buy a set off you. Yeah they turned out well, saved 5kg over what I had previously which is good. Don't think they're "copyable", they have no adustment so are pretty much setup for me, tey feel awesome though I love the on the floor seating position Link to comment Share on other sites More sharing options...
Luxluc Posted October 30, 2010 Share Posted October 30, 2010 Looks good Jay. I went for AP gearshift bushings too when I upgraded my clutch. I have the impression gear stick movement is smoother now. Luc Link to comment Share on other sites More sharing options...
RobSheffield Posted October 30, 2010 Share Posted October 30, 2010 Didnt read it all Jay, do you have a lightweight battery? Link to comment Share on other sites More sharing options...
jevansio Posted October 30, 2010 Author Share Posted October 30, 2010 Luxluc said: Looks good Jay. I went for AP gearshift bushings too when I upgraded my clutch. I have the impression gear stick movement is smoother now. Luc Cheers Luc, cheers for the info RobSheffield said: Didnt read it all Jay, do you have a lightweight battery? Yip, Varley RT25 - 6kg Link to comment Share on other sites More sharing options...
monsween Posted October 30, 2010 Share Posted October 30, 2010 jevansio said: EDIT plus it's only the passenger side, I'll be making sure Paul does the drivers I'll still ask for a passenger ride Link to comment Share on other sites More sharing options...
jevansio Posted November 5, 2010 Author Share Posted November 5, 2010 Should start to see some weight loss progress this weekend. My lexan windows have arrived. Pretty confident still on losing a total of 40kg from the doors. Also just snapped up Rob Sheffields Veilside Teardrop exhaust, not sure on what the savings over the HKS Ti are, hoping for 5kg, should give me a little extra clearance too Link to comment Share on other sites More sharing options...
davej705 Posted November 5, 2010 Share Posted November 5, 2010 Nice rare exhaust aswell,your car keeps getting better mate Link to comment Share on other sites More sharing options...
jevansio Posted November 5, 2010 Author Share Posted November 5, 2010 davej705 said: Nice rare exhaust aswell,your car keeps getting better mate Cheers Dave, I've been umming & ahhhing over this exhaust since Rob decided to break, I knew it would net me some good weight loss, hopefull the 90mm piping won't be too much of a restriction Link to comment Share on other sites More sharing options...
davej705 Posted November 5, 2010 Share Posted November 5, 2010 jevansio said: Cheers Dave, I've been umming & ahhhing over this exhaust since Rob decided to break, I knew it would net me some good weight loss, hopefull the 90mm piping won't be too much of a restriction I doubt it will be,think I read some cars run big big power on a 3inch so should be fine Link to comment Share on other sites More sharing options...
jevansio Posted November 5, 2010 Author Share Posted November 5, 2010 davej705 said: I doubt it will be,think I read some cars run big big power on a 3inch so should be fine I think the 3" flange is the problem, I might have that cut off and turn it into a true 4" dp/mp, 3.5" catback system Link to comment Share on other sites More sharing options...
davej705 Posted November 5, 2010 Share Posted November 5, 2010 What sort of power do you want to end up with? Link to comment Share on other sites More sharing options...
jevansio Posted November 5, 2010 Author Share Posted November 5, 2010 davej705 said: What sort of power do you want to end up with? I dunno, the option of running a 74-76mm, 800bhp. After reading Jamies T6 thread I think I have been put off big bhp Link to comment Share on other sites More sharing options...
JamieP Posted November 5, 2010 Share Posted November 5, 2010 Nice exhaust, yeah id cut the 3" flange off to try and keep as free flowing as possible. jevansio said: I dunno, the option of running a 74-76mm, 800bhp. After reading Jamies T6 thread I think I have been put off big bhp Pussy:D TBH even a 76 is a bit mad for the street, you will have to go to all the expense of wide body and wheels to get any decent traction, id like to see what a 7175 is like myself, should make 800bhp. Link to comment Share on other sites More sharing options...
jevansio Posted November 5, 2010 Author Share Posted November 5, 2010 JamieP said: Nice exhaust, yeah id cut the 3" flange off to try and keep as free flowing as possible. Pussy:D TBH even a 76 is a bit mad for the street, you will have to go to all the expense of wide body and wheels to get any decent traction, id like to see what a 7175 is like myself, should make 800bhp. Defo, no point going with the 3" connection, That thread you started puts a lot of things into perspective bud Link to comment Share on other sites More sharing options...
davej705 Posted November 5, 2010 Share Posted November 5, 2010 jevansio said: That thread you started puts a lot of things into perspective bud It was a bit of an eye opener that thread! Don't let it put you off though! Link to comment Share on other sites More sharing options...
jevansio Posted November 6, 2010 Author Share Posted November 6, 2010 I started with the 1st door today. Boy are these a bitch to fit. 1. The external weather strip has no where to bolt onto the new door. I think I'll end up sik-a-flexing it on. 2. Pretty sure the door mirrors won't bolt on. I think I'm going to take the opportunity and go with some lightweight ones. Gutted as I was hoping to retain a totally stock outside. Not sure if I will go with the carbon GT3/APR type ones, or something else. I'm open to suggestions 3. The 2 bump stops that the window glass hits when it's at the top have no provision to bolt on. I'm now sure how much of an issue this is, do they stop the window falling out the top, or are they just for fine tune of the window position when up? 4. The thing that stops the door swinging open on the stock door is proving a PITA to get out, that little metal rod just won't come out 5. Pretty much every hole that needed a plastic fitting pushing into was too small (I suppose it's better than being too big). I've got a small file now & will have to alter each of them 6. Unsure if I should remove/cut down that big metal plate with the 3 pink plastic fixings on. It's where the door card bolts to the door inside the grab handle, I guess without it the doorcard wouldn't pull the door very well when you close it. 7. The plates in the glass that the frame bolts to look like they need some sort of sst to remove. I'll have to make that tomorrow On the plus side it is light as feck, the lock mechanisms went in perfect, the rubber seal also went on perfect. All in all I am very pleased with them, they are taking a lot longer to fit than I imagined and with a geometry setup & tuning session in the next week or two I'm really going to be under pressure tomorrow to get the dor back into some sort of fitted state that will allow me to drive it (albeit without a wing mirror) Link to comment Share on other sites More sharing options...
JamieP Posted November 6, 2010 Share Posted November 6, 2010 Do-luck mirrors are very nice mate, after a set myself. Link to comment Share on other sites More sharing options...
jevansio Posted November 6, 2010 Author Share Posted November 6, 2010 JamieP said: Do-luck mirrors are very nice mate, after a set myself. Cheers mate, will check them out, I want something light (ie non powered/heated) but think the APR/GT3 style mirrors although light look slightly out of place on anything other than an all out track car (canards/ big wing etc) Link to comment Share on other sites More sharing options...
JamieP Posted November 6, 2010 Share Posted November 6, 2010 (edited) Yeah doluck and non powered or heated so should be pretty light, apr mirrors are horrid, i fitted some to mine for about 2 min and took them off again. EDIT, just checked and the are electric mate. Edited November 6, 2010 by JamieP (see edit history) Link to comment Share on other sites More sharing options...
Luxluc Posted November 6, 2010 Share Posted November 6, 2010 Good progress Jay. Link to comment Share on other sites More sharing options...
