jevansio Posted October 9, 2010 Author Share Posted October 9, 2010 Right I've removed the rear crash bar, it & the bolts & the foam came to 8kg. So now I'm left with the dilema of the unprotected rear. I tried my front crash bar just to see what the fit was like, it went on like a glove on the original mount points. Yes I know it ain't as safe as the steel bar . Current weight 1360kg Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 9, 2010 Share Posted October 9, 2010 1360 for now. Is that with the carbon doors already in? What about the windows .. still glass? Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 9, 2010 Author Share Posted October 9, 2010 1360 for now. Is that with the carbon doors already in? What about the windows .. still glass? No, full fat door & glass still in. They are going to be the next one hopefully this week if the lexan turns up. Hoping to save 40kg for the 2 doors which will put me at 1320kg , easily on target to hit 1300kg Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 9, 2010 Share Posted October 9, 2010 Impressive Jay What weight saving do you estimate on the 3 lexan windows? Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 9, 2010 Author Share Posted October 9, 2010 Impressive Jay What weight saving do you estimate on the 3 lexan windows? Not sure, I haven't catered for the lexan windows themselves, rather incorporated the saving into the total for the doors & hatch which should be -40kg & -15kg respectively Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 9, 2010 Share Posted October 9, 2010 Looks like you are going to make the sub 1300kg easy mate, are you doing this as a track car? Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 9, 2010 Author Share Posted October 9, 2010 Looks like you are going to make the sub 1300kg easy mate, are you doing this as a track car? Yeah, got my eyes set on 1280kg at the mo, depends how things go. Nope road car, granted it's a weekend toy & used mostly in the warmer months, but it'll spend most of it's moving time on the road not the track Quote Link to comment Share on other sites More sharing options...
Abz Posted October 9, 2010 Share Posted October 9, 2010 Wow, sounds like it will have an interesting power to weight ratio Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 9, 2010 Share Posted October 9, 2010 Yeah its going to be quick at 1280kg, get that upto about 800bhp and you got a flying machine:) Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 12, 2010 Author Share Posted October 12, 2010 Put 2.5kgs back on today , put the rear lower seat back in to put an OEM feeling back into the car since I'm going to bust the 1300 barrier. As much as my rear seat delete looked good, it didn't have that Toyota feel to it. On the plus side got some HKS 280's from Whiffin which I'll be fitting this weekend, hoping that will give me 750bhp when mapped and should open up the top end of the revs where I'm really struggling with the jspec exhaust cam Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 13, 2010 Share Posted October 13, 2010 280 cams .. can you comment what idle will be like on your setup. Thanks Luc Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 13, 2010 Share Posted October 13, 2010 .. Quote Link to comment Share on other sites More sharing options...
monsween Posted October 13, 2010 Share Posted October 13, 2010 (edited) Did you have a proper rear seat delete Jay? Fancy selling it then EDIT: just checked your page and you have, interested if your wanting to sell Edited October 13, 2010 by monsween (see edit history) Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 13, 2010 Author Share Posted October 13, 2010 280 cams .. can you comment what idle will be like on your setup. Thanks Luc It will be as smooth as a babies bottom , i actually don't know, I'm just going to install them straight up and see what it's like Did you have a proper rear seat delete Jay? Fancy selling it then EDIT: just checked your page and you have, interested if your wanting to sell It pretty much consists of some foam & a piece of speaker material, I need the material as I have a small gap to fill where the upper seat will go, so i think you would be seriously underwhelmed with what my rear seat delete comprises of . You know I did a thread on it which shows exactly what I did? Will dig it out later for you bud Quote Link to comment Share on other sites More sharing options...
monsween Posted October 13, 2010 Share Posted October 13, 2010 I didnt see that thread, So will use your guide to build mine Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 14, 2010 Author Share Posted October 14, 2010 I fitted the HKS 280 cams today. The shim clearances were EXACTLY the same as both the HKS 264 & JSpec cams I took out. Fired it up & to say it was lumpy would be an understatement . I'd been doing some research on SF on what to expect & what to do. I gave it a bit more fuel, and increased the idle revs (all of this going through a cold start which prolly isn't the best time to be tweaking as things are changing all the time). Anyway once the car was warm & with some little changes to the map it was idling at 1050rpm and sounding pretty fierce. I took it for a short run out just to see what the cruise manners were like, it was a little juddery sometimes at low rpm, but on the whole it feels fantastic. It seems to LOVE revs. Just need to get Ryan to give it a big once over as I think all areas of the map have been affected (coldstart, idle, cruise & WOT), but cannot wait to see what it pulls like top end when its done. Will do a video for you tomorrow Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted October 14, 2010 Share Posted October 14, 2010 I fitted the HKS 280 cams today. The shim clearances were EXACTLY the same as both the HKS 264 & JSpec cams I took out. Fired it up & to say it was lumpy would be an understatement . I'd been doing some research on SF on what to expect & what to do. I gave it a bit more fuel, and increased the idle revs (all of this going through a cold start which prolly isn't the best time to be tweaking as things are changing all the time). Anyway once the car was warm & with some little changes to the map it was idling at 1050rpm and sounding pretty fierce. I took it for a short run out just to see what the cruise manners were like, it was a little juddery sometimes at low rpm, but on the whole it feels fantastic. It seems to LOVE revs. Just need to get Ryan to give it a big once over as I think all areas of the map have been affected (coldstart, idle, cruise & WOT), but cannot wait to see what it pulls like top end when its done. Will do a video for you tomorrow It'll be interesting to see the difference, bet its well rich at the moment isn't it? Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 14, 2010 Author Share Posted October 14, 2010 It'll be interesting to see the difference, bet its well rich at the moment isn't it? It feels amazing mate, I didn't want to give it too much, but I opened it up a bit and kept an eye on the AFR, yip it was down into 10.5 and that wasn't even WOT & full boost. It seriously needs a Ryan G lookover, but I'm over the moon with them. Was starting to get cold feet last night reading on SF that most people that ran them were 80mm+ & 1000rwhp, I thought they may be no good at all for me, but 1st impression is great. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 14, 2010 Share Posted October 14, 2010 You went from 264 to the 280, right? Would be interesting to see what you personally feel in terms of "additional" lag. Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 14, 2010 Author Share Posted October 14, 2010 280 cams .. can you comment what idle will be like on your setup. Thanks Luc You went from 264 to the 280, right? Would be interesting to see what you personally feel in terms of "additional" lag. I went from 264 in/jspec ex to 280 in/ex. Once it's all mapped up I'll let you know although my guts tells me it does feel a little lazy low down (under 3k rpm) but the map sure won't be doing it any favours at the mo Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 14, 2010 Share Posted October 14, 2010 I went from 264 in/jspec ex to 280 in/ex. Once it's all mapped up I'll let you know although my guts tells me it does feel a little lazy low down (under 3k rpm) but the map sure won't be doing it any favours at the mo Good luck with the mapping Jay. It will be interesting to see what comes out after Ryan's magic work Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 15, 2010 Author Share Posted October 15, 2010 Some vids of the idle, I don't think my camcorder can capture the sound very well zQGnre-cc50 a6_qVpd6qSY Quote Link to comment Share on other sites More sharing options...
davej705 Posted October 15, 2010 Share Posted October 15, 2010 that sounds feckin awesome especially when you give it some throttle Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted October 15, 2010 Share Posted October 15, 2010 mate sounds lovely, one of my favourites on here, but get a sponge on that filthy back end lol dont wax it though as im thinking about weight saving lol Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 15, 2010 Author Share Posted October 15, 2010 that sounds feckin awesome especially when you give it some throttle Cheers mate, the camera does not do it justice though mate sounds lovely, one of my favourites on here, but get a sponge on that filthy back end lol dont wax it though as im thinking about weight saving lol Lol, yeah I guess I had better wash it, must be a couple of months now. I quite like the rough look though, makes people not in the know think it's just a knackered old jap car with a oud exhaust Quote Link to comment Share on other sites More sharing options...
