Lude Posted September 24, 2010 Author Share Posted September 24, 2010 the cam covers i would prime first before painting. what primer does this need then? High temp primer aswel? normal? or dont you really need any as the paint itself is ok? ive got my HT spray today, it says for best results use engine enamel primer?? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 24, 2010 Share Posted September 24, 2010 what primer does this need then? High temp primer aswel? normal? or dont you really need any as the paint itself is ok? ive got my HT spray today, it says for best results use engine enamel primer?? I was referring to using 2K paint, if you're using a different type of paint then go with what is recomended for that type. Quote Link to comment Share on other sites More sharing options...
Lude Posted September 24, 2010 Author Share Posted September 24, 2010 ok thanks mate. ive just done the plastic plug cover tonight. lookt a mess & blotchy/spotty at first, after a good few cotes it looks tidy tho, very bright! gona do the metal cam covers tomo, hopefully iv got enough from left from the 1st can to do them both. if it takes as many coates as the plug cover did tho il need another! its probably for metal tho not plastic, so should take less coats. gloss yellow il get pic on here when its all done Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 27, 2010 Share Posted September 27, 2010 I used astral black from halfords for my spark cover, looks fine a year later. Cam covers are going to be polished Quote Link to comment Share on other sites More sharing options...
