TrevS Posted September 20, 2010 Share Posted September 20, 2010 Hi All I know you can get the lexus GS300 sport wheels to fit a MKIV supra but are there any other lexus wheels that will also fit the car? I am toying with the idea of keeping the supra for a while but want to change the wheels. Trev Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted September 20, 2010 Share Posted September 20, 2010 Order a set of LFA wheels . Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted September 20, 2010 Share Posted September 20, 2010 Order a set of LFA wheels . The design would probably suit a Supra quite well Shame they'll most likely be 20"+ Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted September 20, 2010 Share Posted September 20, 2010 I wonder does anyone do a replica set in 18"? Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted September 20, 2010 Share Posted September 20, 2010 They look a bit like the Ultralite Hikari's to me... Which are also very nice indeed. Quote Link to comment Share on other sites More sharing options...
James Posted September 20, 2010 Share Posted September 20, 2010 First things that comes to mind when I see those LF-A wheels are the Work S2Rs:- Lovely wheels. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 20, 2010 Share Posted September 20, 2010 And yes Lexus wheels will fit Toyotas after all theyre the same company 5x114.3 and a 60.1mm centre bore. Quote Link to comment Share on other sites More sharing options...
garethr Posted September 20, 2010 Share Posted September 20, 2010 AFAIK the GS300 Sport wheels with the optional 10" rears were the only staggered wheels fitted to a Lexus. Quote Link to comment Share on other sites More sharing options...
RobD Posted September 20, 2010 Share Posted September 20, 2010 They'll fit but offsets would be different, some will still work well but the lexus wheels seem to corrode quite badly! We change alot of wheels under warranty at my dealership due to corrosion! Personally though either the is-f wheels or is sport wheels Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted September 20, 2010 Share Posted September 20, 2010 Arent the LF-A wheels 20s? would probably make the car feel pretty bad to drive despite looking nice! Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted September 20, 2010 Share Posted September 20, 2010 IS-F wheels are 19" but I believe they're the same width and offset front and rear Quote Link to comment Share on other sites More sharing options...
TrevS Posted September 20, 2010 Author Share Posted September 20, 2010 I did think those ISF wheels would look nice but I bet they would be very expensive. Quote Link to comment Share on other sites More sharing options...
TrevS Posted September 20, 2010 Author Share Posted September 20, 2010 I don't know if ISF wheels would work: However I quite like these from the newer Lexus GS Maybe have them painted grey These ones are from the current GS: Trev Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted September 20, 2010 Share Posted September 20, 2010 There's also the SC430 wheels, though they look horrid! Quote Link to comment Share on other sites More sharing options...
XIL007 Posted September 20, 2010 Share Posted September 20, 2010 wont the wheels of the is 200 sport fit, im sure they were larger at the rear than at the front and there are a few different styles Quote Link to comment Share on other sites More sharing options...
TrevS Posted September 21, 2010 Author Share Posted September 21, 2010 Couple more wheels I like Lexus IS250/350 However, these I REALLY like, Lexus IS250 F-sport I think they are only available in the states though Trev Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted September 21, 2010 Share Posted September 21, 2010 No, the IS-F wheels are available for purchase through your Lexus/Toyota dealer. They are expensive and only 19" (which make them not very optimal for the soop) Quote Link to comment Share on other sites More sharing options...
TrevS Posted September 21, 2010 Author Share Posted September 21, 2010 After a bit of digging I've found that the lexus wheel sizes are: IS250/300 wheels 18x8" Front - 18x8.5" Rears IS250/350 F-sport forged wheels 19x8" front - 19x9" rear ISF wheels 19x8" front - 19x9" rear So I am guessing that these are all too small to fit a supra as I believe the standard wheels are 9.5" rears aren't they? Trev Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted September 22, 2010 Share Posted September 22, 2010 correct. Stock sizes can be seen here: http://mkiv.com/specifications/93_full_brochure/page24.jpg Quote Link to comment Share on other sites More sharing options...
TrevS Posted September 22, 2010 Author Share Posted September 22, 2010 I've managed to find a company to supply some lexus wheels and also a company that will widen the rears in Germany. What would you say the optimal width I should go for is 9.5", 10" etc? Thanks Trevor Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted September 22, 2010 Share Posted September 22, 2010 Well, how about just getting the TTE/Lexus grand stands that already are the right size? 8.5" front and 10" rear? Lots of info on them if you search. I just bought some used. I would not recommend to widen the rear. I'm not saying it wouldn't work, but I myself would not like the uncertainty when driving on track or speeding down the autobahn @ 150mph+... If you don't do that, then go for it. But hey, 9.5 or 10 doesnt make too much of a difference. Why not stick to stock? Or take the .5" to fit some wider wheels for show. I would check the offset first off to see if that is close to stock. If not I would think about going for other wheels. The Grand Stands are ok regarding offset. +40/45 to my recollection. Also think of the offset if you widen the wheels, depending on how it is done this might change and you might not want that. Quote Link to comment Share on other sites More sharing options...
TrevS Posted September 22, 2010 Author Share Posted September 22, 2010 Thanks. The offset of the wheels is +40 which I guess might be ok then, but I think 8.5" on the rear is going to be too skinny isn't it? Are the wheels your referring to the GS300 sport wheels? http://is.gumtree.com/image/big/20517160.jpg Trev Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted September 22, 2010 Share Posted September 22, 2010 They are 8.5" on the front, and 10" on the rear. I have them on mine, and are just about perfect. Chris Wilson agrees, mostly. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted September 22, 2010 Share Posted September 22, 2010 Thanks. The offset of the wheels is +40 which I guess might be ok then, but I think 8.5" on the rear is going to be too skinny isn't it? Are the wheels your referring to the GS300 sport wheels? http://is.gumtree.com/image/big/20517160.jpg Trev Thats the ones. They are 8.5" front and 10" back. TTE in Germany has shut down shop but you should be able to get them from new through a Lexus dealer. Price is roughly 1000-1200£ i think. Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted September 22, 2010 Share Posted September 22, 2010 Thats the ones. They are 8.5" front and 10" back. TTE in Germany has shut down shop but you should be able to get them from new through a Lexus dealer. Price is roughly 1000-1200£ i think. Can you still get the diamond cut finish on them from Lexus/Toyota? Quote Link to comment Share on other sites More sharing options...
