mikeyh Posted September 20, 2010 Share Posted September 20, 2010 can anybody help my gearbox seems to have a slight leak nothing bad but it will annoy me if i dont do it now is it somthing i could change my self, i have use of ramps plus im not totally useless with a spanner;) just need pointing in the right direction is there any good guides i have had a search but i cant find nothing:search: any help would be great Quote Link to comment Share on other sites More sharing options...
mikeyh Posted September 22, 2010 Author Share Posted September 22, 2010 :search:has nobody changed theres Quote Link to comment Share on other sites More sharing options...
edge Posted September 22, 2010 Share Posted September 22, 2010 Its has been discussed quite a few times and supprised you didn't find anything. I will have a looksi Quote Link to comment Share on other sites More sharing options...
edge Posted September 22, 2010 Share Posted September 22, 2010 http://www.mkivsupra.net/vbb/showpost.php?p=1921833&postcount=27 All i can find. I'm sure there was a guide or a more in depth thread about it. Its not a hard job, just fiddly. Quote Link to comment Share on other sites More sharing options...
mikeyh Posted September 22, 2010 Author Share Posted September 22, 2010 i did have a look but nothing concrete on this job:( its just i want an idea of how to do it so i dont make more work for myself or manage to screw it up;). Quote Link to comment Share on other sites More sharing options...
edge Posted September 22, 2010 Share Posted September 22, 2010 i did have a look but nothing concrete on this job:( its just i want an idea of how to do it so i dont make more work for myself or manage to screw it up;). I done mine when the box was out of the car when i done the clutch and fly. They say you can do it without removing the box and i remember a post of someone saying you could get to it from inside the car but i wouldn't know what was easier. Quote Link to comment Share on other sites More sharing options...
mikeyh Posted September 22, 2010 Author Share Posted September 22, 2010 i think i will have to have another search see if i can see anything Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 22, 2010 Share Posted September 22, 2010 (edited) It is easier and safer not to remove the old seal. If you scratch the bore in an attempt to remove the old one, it will always leak no matter how many new seals you put in. I made up a simple tool from copper tube to push the old seal back a bit and then to insert the new seal. You can drop the back of the box to get at it under the car. From inside the car I would have thought it would be a pig of a job. I did mine out of the car, this post shows what you are dealing with. You really need the best access you can get. Edited September 22, 2010 by Terminator (see edit history) Quote Link to comment Share on other sites More sharing options...
Paul Posted September 22, 2010 Share Posted September 22, 2010 Phil, did the double seal stop yours leaking? Phoenix did that with mine but it still weeps Maybe I should go fo a third one Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 22, 2010 Share Posted September 22, 2010 Phil, did the double seal stop yours leaking? Phoenix did that with mine but it still weeps Maybe I should go fo a third one Yes bone dry ever since. If the bore is scratched it will never seal completely. Not sure how many seals can be squeezed in;) Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted September 23, 2010 Share Posted September 23, 2010 Info on the process here: http://www.supraforums.com/forum/showthread.php?t=396382 Quote Link to comment Share on other sites More sharing options...
mikeyh Posted September 23, 2010 Author Share Posted September 23, 2010 Info on the process here: http://www.supraforums.com/forum/showthread.php?t=396382 thats just what ive been looking for somthing that puts me in the right direction thanks for the info guys Quote Link to comment Share on other sites More sharing options...
dwayne Posted October 8, 2010 Share Posted October 8, 2010 i just started doing mine and i've already rounded off one of the prop bolts on the gearbox side looks like the knackered seal has eaten my gearbox mount aswell so i need a new one of them too. the guy on SF says its an easy job at the end of his post but i've already swore plenty of times! Quote Link to comment Share on other sites More sharing options...
