marc_p Posted September 19, 2010 Share Posted September 19, 2010 Ok, I want to get this sorted before the engine goes in the aerotop, the TT engine starts and runs nice(bar a little low idle that is imo the ICV) under acceleration it goes perfect, no complaints, but when I switch the engine off I get a knocking/clunking sound, has anyone got any ideas or had this before? Quote Link to comment Share on other sites More sharing options...
edge Posted September 20, 2010 Share Posted September 20, 2010 The 6 speeds are noisy dude and can rattle when turning off. What clutch you running aswel? Get a little bid or audio clip up Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted September 20, 2010 Share Posted September 20, 2010 sounds like the clutch mate Quote Link to comment Share on other sites More sharing options...
marc_p Posted September 20, 2010 Author Share Posted September 20, 2010 The 6 speeds are noisy dude and can rattle when turning off. What clutch you running aswel? Get a little bid or audio clip up sounds like the clutch mate Cheers guy's:thumbs:, thinking about it, it sounds like it will be the clutch as when I tried to listen to where it was coming from, it did sound like that 'area', in regard to what clutch it is, it's standard as far as I know. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 20, 2010 Share Posted September 20, 2010 It's probably a worn out dual mass (stock) flywheel, but make sure it's not a LOOSE flywheel, as they quickly ruin the crankshaft. Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted September 20, 2010 Share Posted September 20, 2010 get a southbend clutch, had exactly the same problem. fitted the new SB clucth and it was solid after that, no knocks what so ever! Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 20, 2010 Share Posted September 20, 2010 turn it off with the clutch pedal down and I suspect it won't be noisey................ Also I would very much recommend getting the pre facelift engine mount brackets and brand new prefacelift engine mounts when installing this into the aerotop. The facelift mounts will fail and are a real pain to change in situ.. Quote Link to comment Share on other sites More sharing options...
marc_p Posted September 26, 2010 Author Share Posted September 26, 2010 turn it off with the clutch pedal down and I suspect it won't be noisey................ Also I would very much recommend getting the pre facelift engine mount brackets and brand new prefacelift engine mounts when installing this into the aerotop. The facelift mounts will fail and are a real pain to change in situ.. Cheers fella, I did this yesterday and got no rattle/clunking, looks like it is just the clutch. Cheers guys:) Quote Link to comment Share on other sites More sharing options...
