Team Falken UK 650hp V35 Skyline (G35)
Polo
etc etc
Gearbox mount
Neither the engine or gearbox mounts are finished yet, just fitted for now until iv made the sump, then once i take the motor back out to do the rest of the shell prep il finish the bracing on the mounts.
Started to make the sump, mesured it takes 5ltrs, so once im done i want it to hold as close to that as poss again.
  • Replies 140
Been at it again today, got the sump prety much finished! Left on of the sides open until iv made the new pick up, to make it easier. Also need to do a leak test on it once the welding is finished.
Phase two, make it hold 5ltrs again,
So i got the engine back out to sort the trany tunnel, slight bodding needed to clear the bellhousing.
Thats as far as i got! My angle grinder died so need a new one of them befor i continue, next it to trianglate the engine and gear box mounts. Then get the rest of the sound proofing out and start the seam welding.
Not really alot to update,
Seing as its and auto shell and its going to be manual, a little work is needed in this area. I managed to get a manual brake and clutch pedal from some one on another forum, but there was no where to really mount it like on s-bodies, also, i could not find a slave for a 350gt or z so im using an s14 one, so.................
Holes line up but itl put the cylinder on the piss,
Welded in a spreader plate as the bulk head is soo flexable
welded in some studs to make fitting easier
In the car
Managed to pic up this accusump and a load of -12 fittings for pennies,
i done the sums and new this lot is very close to £1k!!!!
then got on with getting the shite proofing out!!!
  • 2 weeks later...
Thanks guys!!
Bit of an update!!! Sound proofing is finaly out and most the prep for seam welding done!!!! you think an s14 is bad!! try one of these!! Iv spent 4-5 nights, my bro and my girlfriend a day each and a mate 2 hole days!!!!
Got some good second hand Cobra seats and some new rails,
and made some cross rails to hold the seat in, still need to do the other side, but that does not need to be in any particular posision,
Then got on with some of the seam welding and sealing some of the un-needed holes in the bulk head,
Thanks for the comments :)
Could a mod please change the name of the thread to "Team Falken UK 650hp V35 Skyline (G35) "
bit of an update, not got alot done this week, lost a bit of motivasion tbh!!
Parts arived over the week
1000cc bosch injectors and pig tails
Mocal 24 row engine oil cooler with -12 fittings
Mocal sandwich plate with -12 fittings
13 row cooler for gearbox cooling system, iv also got a remote filter and big Mocal oil pump for the system.
low mile s14 diff cooler to be used to cool power steering fluid
And iv got on with some of the seam welding, the welding its self takes hardly any time, its the cleaning the paint and sealer that takes ageees!!
Also had time between jobs in the day to trim the dash and see how it fits around the dash
  • 8 months later...
wah wo wah!!! just paid up for the 20 years!!! Sorry i didnt do it sooner guys, but i ran out of time to update this!!! Car was finished on time and iv been using it since april every other week!! Im guessing those at japfest would have seen it??
Update the thread then, we are all in for the pics :D
mate, do you relise how many more updates there wer after this 5 pages!! other forums wer up to 25 pages lol. When i get a tad more time il sort some thing out ;) made 607hp and 615ftlb bty, thats at only 1.6bar boost and 6200rpm limit.
Other wise look here http://www.driftworks.com/forum/drift-car-projects-builds/124180-team-falken-uk-650hp-v35-skyline-g35.html
  • 2 months later...
Thoght id update this while having my lunch today. This is going to be copied from another forum so some of it might not make sence, bear in mind this was all over last winter lol.
Time to resurrect this thread!!!
I was thinking of selling it and moving onto some thing else through out the year but in Portugal it worked and I came 4th so it's given me some confidence that it can work!!
Throgh out the year iv had endless problems with the car, mainly power steering and transmission. Iv cured the power steering by fitting a 350z pump.
So over the winter il be doing the following to make it a hole load more awesome!!
Handling is prety bad and it feels like a bus to drive, so il be fitting/making fibre glass doors, front wings, rear 1/4s, boot and bonnet, chopping out all the metal I can with in the rules! Also to level up the weight loss and make it handle better I'm shifting weight around in the car for better distribution by moving the rad and other things to the back. Il also be remaking alot of things in light weight materials.
Steering lock is a major issue with the car, loosing out in qualification due to weak angle so il be doing alot of work on the front steering and suspension.
The car is going to be corner weighted next week so I have an idea of what iv got to work with and then compare it afterwards.
Il also be fitting a v160 6spd box, this will be much better suited to the 3.4:1 diff I have now, which is alot of the problems I'm having with blowing boxes, ATM pulling away in 1st is like 2nd gear as it's so long geared!
The other thing I'm going to do if I can afford it is change the hks ecu out for syvecs and go for closer to 700hp.
To help with the power I'm hoping to freshen up the engine with rods, pistons, springs and cams.
Right, I'm off the rob a bank lol
Bit of an update, shes now prety much ready to go off to have the cage, inside and engine bay painted, 3 weeks after id planned but shit happens!!
More stripping, i forever seem to be unding nuts and bolts on this, its never ending :wack:
Big old alloy subframe
very clean under there, not a spec of rust!!!
And finished the seam welding, finaly!!!!
Then a good coat of stonechip
Should have the paint inside done by next weekend and i can finaly start final fitting stuff.
Small update, the body shop is strugling to fit it in to get the engine bay and inside painted so iv not really done alot with it!
But it is now ready for paint inside and engine bay
Started playing with the dash, chopped out the centre, if you look back in the thread youl see the centre bit has loads of switchs in it for stereo, heater, dvd etc etc.
Holes for 16 switchs,
Ignition
fuel pump 1
fuel pump 2
fans bypass
side lights
dip beam
main beam
indicators
rear fog
wipers
screen wash
horn
heater
hazards
elec window
oil/intercooler/rad spray bar
A tray at the top to house boost controller, knock meter and gearbox oil temp gauge.
A load of elec parts orderd, fues boxs, relays, junction boxs, switchs etc etc
Finaly picked up sexy turboness!!Big thanks to OwenDevelopments! GT35/86r with HTA billit comp wheel and WRC metal bearing case!
standard comp wheel
HTA wheel
The turbo even gets its own little oil filter!!
-10 oil return flange
Also took a trip up to EPRacing and collected some bits a bobs
Nardi wheel, snap off boss, oil temp gauge for gearbox and locking catchs for bonnet and boot, as its going to be road legal.
Also got this nice grill
And thanks to MrSteveo i now how a shifter extension :smokin:
Any ways, today we got paint!! WOOP WOOP!! Oh and my custom prop arived!! :D
So we got it in the booth this morn! Masive thanks to Matt Carter for towing it out of my snow filled yard with his 4x4!! And Robbin for getting the paint on and done so quick!!
Epic win in the ice, no need for dollies, we wer just pushing the car where we wanted, slid like a hover craft!
In the booth, final bit of scotching, degreasing and masking
Robbin has quite a few Porchers at his place!! 5 inside and 4 outside!
Then some paint and a bake!
Demasked and back at mine
So now i can finaly start bolting on the pile of bits iv got sitting here!! Full steam ahead!!
