Coolant
jimwire
This is probably a stupid question but can anyone confirm what I think?
I have coolant leaking out the bottom of the air con rad. I suspect it's the main radiator leaking and it's spraying on the air con rad and coming through the fins. I can't see where it's leaking from without draining the coolant and removing the main radiator.
I just need to know if the coolant goes through the air con rad or if it's a seperate system? It's def. coolant and not condensation.
  • 4 weeks later...
