JakeG Posted September 17, 2010 Share Posted September 17, 2010 Was thinking I need my rear wheels sitting out abit more, they don't look good the way they are, just asking if anybody knows what size of spacer I should get to fill the arches more?? Link to comment Share on other sites More sharing options...
Jamesy Posted September 17, 2010 Share Posted September 17, 2010 blimey - about 25mm id say mate Link to comment Share on other sites More sharing options...
JakeG Posted September 17, 2010 Author Share Posted September 17, 2010 Forgot to mention my new wheels will be 9.5x18 on the rear, not sure if that will make any difference? Link to comment Share on other sites More sharing options...
Gaz6002 Posted September 17, 2010 Share Posted September 17, 2010 I'd advise you get some wheels that fit correctly in the first place Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted September 17, 2010 Share Posted September 17, 2010 you got a space saver fitted there? i agree with jamesy about 25mm at a guess Link to comment Share on other sites More sharing options...
Gaz6002 Posted September 17, 2010 Share Posted September 17, 2010 Forgot to mention my new wheels will be 9.5x18 on the rear, not sure if that will make any difference? Of course - but it depends on the offset. Link to comment Share on other sites More sharing options...
JakeG Posted September 17, 2010 Author Share Posted September 17, 2010 you got a space saver fitted there? i agree with jamesy about 25mm at a guess Sorry space saver? Link to comment Share on other sites More sharing options...
JakeG Posted September 17, 2010 Author Share Posted September 17, 2010 Of course - but it depends on the offset. 9.5x18 5X114 ET35, does this help? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted September 17, 2010 Share Posted September 17, 2010 Sorry space saver? one of those skinny wheels in the boot of some cars to get you home... you need the correct offset wheel at the back but spacers will do the job if you would be happy with that mate. Link to comment Share on other sites More sharing options...
Jamesy Posted September 17, 2010 Share Posted September 17, 2010 is your car a wide arched one? if its not your wheels are probably around 18x7j wide which is pretty lame for a supra, especially the rear. as mentioned above best to get proper fitting wheels, failing that a minimum of a 25mm spacer will bring it out an inch which should be more flush..... stick a ruler against your rim and see how far 25mm will bring it out. Link to comment Share on other sites More sharing options...
JakeG Posted September 17, 2010 Author Share Posted September 17, 2010 Thanks guys, will look into finding 25mm spacers Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted September 17, 2010 Share Posted September 17, 2010 (edited) ill try and dig a link out to help, i might need spacers on the front of mine until i can afford new rims http://www.mkivsupra.net/vbb/showthread.php?t=222351&highlight=spacers might help, pm bigsupra http://www.mkivsupra.net/vbb/showthread.php?t=228592 he might sell you these if he can get the other one off Edited September 17, 2010 by Rob_Mitchell (see edit history) Link to comment Share on other sites More sharing options...
Jamesy Posted September 17, 2010 Share Posted September 17, 2010 Thanks guys, will look into finding 25mm spacers I might have some 25mm hubcentric spacers for sale very shoprtly Link to comment Share on other sites More sharing options...
JakeG Posted September 17, 2010 Author Share Posted September 17, 2010 http://cgi.ebay.co.uk/20-mm-BOLT-HUB-SPACER-KIT-TOYOTA-SUPRA-ALLOY-WHEELS-/190439278655?pt=LH_DefaultDomain_3&hash=item2c5710c83f#ht_4025wt_782 Seen these 20mm ones, Jesus I wasn't expecting these things to be that dear Link to comment Share on other sites More sharing options...
Nic Posted September 17, 2010 Share Posted September 17, 2010 9.5x18 5X114 ET35, does this help? You won't need spacers for those, the tyres will sit close to the wheel arches as they are. Link to comment Share on other sites More sharing options...
Jamesy Posted September 17, 2010 Share Posted September 17, 2010 have u seen the pics Nic in #1 Link to comment Share on other sites More sharing options...
Gaz6002 Posted September 17, 2010 Share Posted September 17, 2010 Forgot to mention my new wheels will be 9.5x18 on the rear, not sure if that will make any difference? have u seen the pics Nic in #1 Think he's getting new wheels mate Link to comment Share on other sites More sharing options...
Jamesy Posted September 17, 2010 Share Posted September 17, 2010 ahh i see said the blind man!! what size are the current ones then mate and we can tell u how much more they will sit out? Link to comment Share on other sites More sharing options...
pedrosixfour Posted September 17, 2010 Share Posted September 17, 2010 I've got a pair of 25mm bolt on spacers available if you need them dude. But as said you won't need spacers with the new wheels. Link to comment Share on other sites More sharing options...
JakeG Posted September 17, 2010 Author Share Posted September 17, 2010 I've got a pair of 25mm bolt on spacers available if you need them dude. But as said you won't need spacers with the new wheels. Cheers if I need them il pm you, when the new rims arive I will see how they sit then thanks for the help lads! Link to comment Share on other sites More sharing options...
dandan Posted September 17, 2010 Share Posted September 17, 2010 If you're sticking a 275 35 tyre on there and don't want to roll the arches you'll be pretty close so I'd do nothing until you have some miles on the new setup...you could get a 5mm spacer in there but that means fitting longer studs. If you go 265 35 then in reality you could just about get away with a 15mm spacer as the tyre shape frees up more space than the (relatively fat sitting) 275 35 on a 9.5" rim. If you are happy to roll the arches then you can go a little more crazy Link to comment Share on other sites More sharing options...
merckx Posted September 17, 2010 Share Posted September 17, 2010 You won't need spacers for those, the tyres will sit close to the wheel arches as they are. Correct of course, the offset being 35mm will bring them out towards the arch. Link to comment Share on other sites More sharing options...
Dnk Posted September 17, 2010 Share Posted September 17, 2010 (edited) 9.5x18 5X114 ET35, does this help? They wont need spacers !! These are 9.5 x 18 and im sure their a 35 offset, they are 35, i just checked with the manufacturer Edited September 18, 2010 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
