Stupid Question of the Day
GlennK
I've just filled up after yesteday's mapping session. I was almost on Empty. I put in 73.8l into my tank. But I thought the standard tank holds 70l. And - I checked for leaks. None.
How's this possible?:blink:
What's the maximum you have put into your tank?
Seems strange to have got that much extra in but i wouldnt overly worry about it. You have just reminded me about a fuel query
Rather than start a new thread, i have a quick question regarding the gauge.
Where abouts is the needle in your cars when the light comes on?
After fitting new dials, i filled the car up and placed the needle back on the full mark. Now the light comes on when it gets to the last line before the empty section which i think is slightly high but cant remember where it used to come on before. Think i may need to move it slightly lower.
(hope you dont me posting this in here, just thought i would join the stupid thread :) )
I always fill it up to the top of the neck (and only ever had a max fill of 65l in the past) - the only thing that's changed is the stock pump has been replaced with the Bosch one. But 4l worth of displacement saved? I don't think so.
Tony, It's Tesco Napier Road Reading - 99 RON and only 116.9ppl!! But good point - maybe their metering is off.....
And I didn't get as low as the warning light coming on. And I have the Speedhut stick on dials too. I'll keep a watch next time.
Mine was pretty much as the needle met the very end of the scale.
My gauge fluctuates, didn’t they have a extended tank option ?
I filled up with super from the first mark past E cost me about £55 till the pump click
:search:
Good point. Mine's a JDM import. Here's the spec sheet:
Mark IV
Also called Toyota Supra MK IV
Production 1993–2002
Platform JZA8x
Engines 3 L (2997 cc, 183 cu in) 2JZ-GE I6, 3 L (2997 cc, 183 cu in) 2JZ-GTE I6
Transmissions 5-MT W58, 6-MT V16x, 4-Speed A341E automatic
Wheelbase 2550 mm
Length 4515 mm
Width 1811 mm
Height 1265 mm
Curb weight 1460 kg ~ 1581 kg
Fuel capacity 70 litres
So...still a bit of a puzzle.
