gazzi123 Posted September 16, 2010 Share Posted September 16, 2010 Hi all, got few questions: 1 - at idle (sitting at lights etc) when revs drop below 1000, the car starts to have a high pitch humming noise any ideas? 2 - very faint/slight knocking noise on straight road surface (slightly uneven) - but when going over speed humps there is nothing (maybe illiminating shock problems)? 3 - when clutch not compressed get a ticking/very faint grinding noise - when clutch compressed (changing gears etc) the noise goes away? Cheers all Link to comment Share on other sites More sharing options...
bodilx6 Posted September 16, 2010 Share Posted September 16, 2010 1 - where is this coming from? Can it be the fuel pump? 2 - again, where? Is it from the suspension, dash, gearbox? 3 - is this while driving or at idle? In gear or neutral? Link to comment Share on other sites More sharing options...
gazzi123 Posted September 16, 2010 Author Share Posted September 16, 2010 1 - where is this coming from? Can it be the fuel pump? 2 - again, where? Is it from the suspension, dash, gearbox? 3 - is this while driving or at idle? In gear or neutral? 1 - It sounds like engine bay the humming noise (no idea if it can be fuel pump what should i check for this)? 2 - Noise deffinatly more on passengerside towards the front (owner before me replaced both rear shocks so unknown if that could be problem) once again what should i check? 3 - its both whilst driving + neutral for example: When at traffic lights in neutral and clutch is up (no gear selected) it will make the ticking noise. When clutch compressed/compressed during gear changes noise goes away......then once gear change complete when clutch is raised all the way up noise will start again. any ideas? or what i should check for? Cheers mate Link to comment Share on other sites More sharing options...
csa Posted September 16, 2010 Share Posted September 16, 2010 1 - could be your fuelreg. Link to comment Share on other sites More sharing options...
gazzi123 Posted September 16, 2010 Author Share Posted September 16, 2010 1 - could be your fuelreg. cheers - any idea the best way to test/check. all i want is bring supra back to life (as good as new - well best i can get it) want it mechanically sound. Got any reliable contacts/buisness where i can get parts like this for the Supra ? Cheers Link to comment Share on other sites More sharing options...
bodilx6 Posted September 16, 2010 Share Posted September 16, 2010 1 - as Christian said. It sounds like a fuel issue. I would pop the hood and go listen. If the engine drowns out the noise, you can get a cheap "point-stethoscope" at a well assorted auto acc shop and then see if you can find it. If it is from the front its not the pump as that is in your tank. 2 - could be A LOT of things. If it was from the back, it would be a common supra thing, the rubber stoppers in the hatch. If it is from the front, it might be your suspension, but it is hard to tell as it is only there at certain bumps, right? I would get the car on a lift and then go poke around to see if any thing moves where it shouldn't. Check ball joints, droplinks and generally look if you have any leaks from dampers or how your bump stops look. They might have come loose or have broken. That can give the sound you describe. 3 - if you park a somewhere silent, put the car in neutral and press the clutch, it goes away? then when you let it in, you get a bit more sound. That is normal. But you shouldn't hear anything while driving. The 6sp box can make a lot of funky noises as it is build like a tank, but usually only when shifting or (de)clutching. This can be a bit more tricky, so maybe you should get someone who knows their supra stuff to take a look at the gear box through the inspection holes that you can get to by removing a couple of covers on the bell housing. Not being UK I can't say for sure but I have great experiences with Paul Whiffin of Whifbitz and Chris Wilson. Do a search on both here on forum for more info. Whifbitz being an online shop and Chris being a hard core tech/suspension guru. Link to comment Share on other sites More sharing options...
gazzi123 Posted September 16, 2010 Author Share Posted September 16, 2010 1 - as Christian said. It sounds like a fuel issue. I would pop the hood and go listen. If the engine drowns out the noise, you can get a cheap "point-stethoscope" at a well assorted auto acc shop and then see if you can find it. If it is from the front its not the pump as that is in your tank. 2 - could be A LOT of things. If it was from the back, it would be a common supra thing, the rubber stoppers in the hatch. If it is from the front, it might be your suspension, but it is hard to tell as it is only there at certain bumps, right? I would get the car on a lift and then go poke around to see if any thing moves where it shouldn't. Check ball joints, droplinks and generally look if you have any leaks from dampers or how your bump stops look. They might have come loose or have broken. That can give the sound you describe. 3 - if you park a somewhere silent, put the car in neutral and press the clutch, it goes away? then when you let it in, you get a bit more sound. That is normal. But you shouldn't hear anything while driving. The 6sp box can make a lot of funky noises as it is build like a tank, but usually only when shifting or (de)clutching. This can be a bit more tricky, so maybe you should get someone who knows their supra stuff to take a look at the gear box through the inspection holes that you can get to by removing a couple of covers on the bell housing. Not being UK I can't say for sure but I have great experiences with Paul Whiffin of Whifbitz and Chris Wilson. Do a search on both here on forum for more info. Whifbitz being an online shop and Chris being a hard core tech/suspension guru. Cheers mate ill have a look and get in contact with chris. Yea i parked car in an alley whilst driving - with walls either side to bounce sound off. in neutral + clutch not being compressed sound is there and when reving it just more frequent (once i hit 3/4000revs it goes) when clutch compressed the sound totally goes. Cheers mate for your help really appreciate it fingers crossed - just want to make my supra mechanically sound + enjoy it Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 16, 2010 Share Posted September 16, 2010 If the noise goes when you depress the clutch fully it's the gearbox, probably bearings. Check the oil level and live with it. Link to comment Share on other sites More sharing options...
gazzi123 Posted September 16, 2010 Author Share Posted September 16, 2010 If the noise goes when you depress the clutch fully it's the gearbox, probably bearings. Check the oil level and live with it. Oil levels checked - oil is clean as a whistle - bearings in gearbox must be then - Does that mean i need new/to recon the gearbox then? Cheers Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 16, 2010 Share Posted September 16, 2010 It's such an expansive job I'd just live with it unless it gets really bad or something else occurs like poor synchros or jumping out of gear. A second-hand box may well be as bad or worse, the 5 speed ones are prone to going noisy. Link to comment Share on other sites More sharing options...
csa Posted September 17, 2010 Share Posted September 17, 2010 cheers - any idea the best way to test/check. all i want is bring supra back to life (as good as new - well best i can get it) want it mechanically sound. Got any reliable contacts/buisness where i can get parts like this for the Supra ? Cheers IF it's the fuereg, try giving it a few careful kocks with a finger. You might be able to hear changes in the sound. If nothing happens I'd say it's coming from somehere else Link to comment Share on other sites More sharing options...
gazzi123 Posted September 20, 2010 Author Share Posted September 20, 2010 IF it's the fuereg, try giving it a few careful kocks with a finger. You might be able to hear changes in the sound. If nothing happens I'd say it's coming from somehere else 1 - as Christian said. It sounds like a fuel issue. I would pop the hood and go listen. If the engine drowns out the noise, you can get a cheap "point-stethoscope" at a well assorted auto acc shop and then see if you can find it. If it is from the front its not the pump as that is in your tank. 2 - could be A LOT of things. If it was from the back, it would be a common supra thing, the rubber stoppers in the hatch. If it is from the front, it might be your suspension, but it is hard to tell as it is only there at certain bumps, right? I would get the car on a lift and then go poke around to see if any thing moves where it shouldn't. Check ball joints, droplinks and generally look if you have any leaks from dampers or how your bump stops look. They might have come loose or have broken. That can give the sound you describe. 3 - if you park a somewhere silent, put the car in neutral and press the clutch, it goes away? then when you let it in, you get a bit more sound. That is normal. But you shouldn't hear anything while driving. The 6sp box can make a lot of funky noises as it is build like a tank, but usually only when shifting or (de)clutching. This can be a bit more tricky, so maybe you should get someone who knows their supra stuff to take a look at the gear box through the inspection holes that you can get to by removing a couple of covers on the bell housing. Not being UK I can't say for sure but I have great experiences with Paul Whiffin of Whifbitz and Chris Wilson. Do a search on both here on forum for more info. Whifbitz being an online shop and Chris being a hard core tech/suspension guru. Ive had a good long check for 15minutes - i can hear it clearly when the bonnet is up and im crouching down by the drivers front wheel/wing (right hand drive car). when im leaning into engine bay or in front of car i cannot hear it. Any ideas? Link to comment Share on other sites More sharing options...
Scott Posted September 20, 2010 Share Posted September 20, 2010 Going by your clutch scenario I would guess gearbox. However, another option.... Power steering? Turn the wheel and see if the noise gets louder. It tends to do that when the mesh filter gets clogged with crap or the pump isn't working 100%. Try bleeding it out as best you can by going lock to lock with the steering wheel a few times. When at full lock, hold it there for 5 seconds. Link to comment Share on other sites More sharing options...
dude Posted September 20, 2010 Share Posted September 20, 2010 Noises are very hard to diagnose without hearing them, try listening with a long screwdriver to various parts, fuel reg, pulsation damper and PS reservoir etc, you will be surprised what you can hear. If you still have no joy pop the car down to AFR and we will try and find your noises and advise how you can go about fixing them, doesn't cost anything for a quick look over;) Link to comment Share on other sites More sharing options...
Robzki Posted September 20, 2010 Share Posted September 20, 2010 Couldn't this be the thrust release bearing? As you say hard to say without hearing it. Also I'm auto, So have no experience with manual supras Link to comment Share on other sites More sharing options...
marc_p Posted September 20, 2010 Share Posted September 20, 2010 Couldn't this be the thrust release bearing? As you say hard to say without hearing it. Also I'm auto, So have no experience with manual supras That's what I was going to say, in my opinion, this is the clutch release bearing, however without actually hearing it, it is only speculation. EDIT: Wooohooooo 7000 posts Link to comment Share on other sites More sharing options...
neo2810 Posted September 20, 2010 Share Posted September 20, 2010 Nooooo.... before you start forking out money, check all your heat shields. I've got the same issue with a humming which goes away when clutch depressed and it looks like it's just the deteriorating CAT heatshield. It could be any of the shields around the engine though. Check em all and either pop rubber wedges in or tighten them up. Link to comment Share on other sites More sharing options...
Robzki Posted September 20, 2010 Share Posted September 20, 2010 If the noise goes away when you put a little pressure on the clutch pedal I'd say thrust bearing. If it only goes away when its right down then its tricky to pinpoint without being there. Link to comment Share on other sites More sharing options...
gazzi123 Posted September 20, 2010 Author Share Posted September 20, 2010 Noises are very hard to diagnose without hearing them, try listening with a long screwdriver to various parts, fuel reg, pulsation damper and PS reservoir etc, you will be surprised what you can hear. If you still have no joy pop the car down to AFR and we will try and find your noises and advise how you can go about fixing them, doesn't cost anything for a quick look over;) Ah cheers matey - ill av a look most day today , if no luck ill definatly pop down mate Cheers everyone its made me realise how many more things could be cheers peeps really appreciate it Link to comment Share on other sites More sharing options...
