Walbro foam sleeve and wiring
Robzki
Just a quick question, I am in the midst of fitting a walbro in tank fuel pump(sytec). The kit comes with a foam sleeve, Do I use this? I'm 99% sure I should but wanted to check that everyone else does too. I assume it is a noise suppressant?
Also has anyone removed the pins from the upper plug and soldered those onto the replacement wires for the new pump?
Thanks
Rob
