fastcar Posted September 15, 2010 Share Posted September 15, 2010 Hi peeps Just brought a Greddy profec B-spec 11. Have had a read through the instruction and pretty much sorted about where the pipes NO and COM plug into. But there is a third pipe that goes from the fuel pressure regulator to the back of the main unit. Question is where is the fuel pressure regulator located? Says in the manual that this pipe needs to be fitted between the intake manifold and the pressure controll solenoid valve. Any help would be great. Pics would be best. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted September 15, 2010 Share Posted September 15, 2010 This may help you, it also has a guide for the Blitz boost controller but the principals should eb the same http://www.mkivsupra.net/vbb/showthread.php?t=155699 Instruction manual http://www.greddy.com/upload/file/PRofec_Bspec2.pdf A guide with some pics in here http://www.mkivsupra.net/vbb/showthread.php?t=150861&highlight=profec Quote Link to comment Share on other sites More sharing options...
fastcar Posted September 15, 2010 Author Share Posted September 15, 2010 Thanks for that. but im looking for the fuel pressure regulator line. Thanks for the help anyways:) Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 15, 2010 Share Posted September 15, 2010 That pipe sounds like it's the boost pressure reference hose for the boost controller. This is so the BC knows what boost you are at. The FPR is located on the top of the fuel rail, towards the front of the engine. Make sure you refit the hose to the FPR properly and that there are no leaks or possibility of blowing a hose off. You will run lean if that happens and potentially lose your engine. Quote Link to comment Share on other sites More sharing options...
fastcar Posted September 15, 2010 Author Share Posted September 15, 2010 Nice one Ian. Just to make sure i have the right one. is it the pipe i have marked in red on the pic. If it is i have my boost gauge connected to it. Will it be fine to connect a second line the pipe or should i connect it the boost gauge pipe? Quote Link to comment Share on other sites More sharing options...
fastcar Posted September 16, 2010 Author Share Posted September 16, 2010 sorted!!! Thanks dor your help:) Quote Link to comment Share on other sites More sharing options...
