Homer Posted September 14, 2010 Share Posted September 14, 2010 Hopefully a simple yes/no answer on this: Can the stock front brake lines from the smaller "jspec" calipers be used when changing the calipers to the larger "UK" ones? Reading back through previous threads there were mixed opinions but couldn't see a definitive answer. Quote Link to comment Share on other sites More sharing options...
heckler Posted September 14, 2010 Share Posted September 14, 2010 Yes. When I swapped from jspec to uk's the hoses fitted fine, front and back Quote Link to comment Share on other sites More sharing options...
Homer Posted September 14, 2010 Author Share Posted September 14, 2010 Thanks Si, just to confirm, did you use stock jspec rubber hoses or aftermarket braided ones? Quote Link to comment Share on other sites More sharing options...
heckler Posted September 14, 2010 Share Posted September 14, 2010 Stock rubber ones. Now have braided. No difference in fit Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 14, 2010 Share Posted September 14, 2010 if you are putting uk spec on you should really put better braided hoses on too. Quote Link to comment Share on other sites More sharing options...
Homer Posted September 14, 2010 Author Share Posted September 14, 2010 Stock rubber ones. Now have braided. No difference in fit Cool, thanks mate if you are putting uk spec on you should really put better braided hoses on too. The stock UK's came with rubber hoses so I don't see why braided ones are considered essential. They might offer a tiny improvement in pedal feel, but surely that's all they do? The thing I don't like about most braided hoses is they miss the support braket which can cause them to rub on the suspension arms. Not sure if the latest Goodrich ones have these but the last set I bought didn't have them. Quote Link to comment Share on other sites More sharing options...
Andy Blyth Posted September 14, 2010 Share Posted September 14, 2010 100% the same They have the same part numbers. Front 47330-14010 Rear 90947-02745 Quote Link to comment Share on other sites More sharing options...
Homer Posted September 14, 2010 Author Share Posted September 14, 2010 Brilliant, that's what I wanted to hear, thanks Andy I never even thought to check epc, doh! Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 15, 2010 Share Posted September 15, 2010 I fitted braided hoses and I recall the pedal feel was hugely improved. Might be part placebo though as you have to put in new fluid and fully bleed the system anyway, which should improve matters as well. They don't rub on the suspension arms if you put them on the right way round Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 15, 2010 Share Posted September 15, 2010 They do make a noticeable difference in pedal feel, but so does leaving out the anti squeal shims. Quote Link to comment Share on other sites More sharing options...
Shane Posted September 15, 2010 Share Posted September 15, 2010 Just this afternoon I ordered a set of Hel braided brake lines and they were listed as JZA80, no mention of either uk or jspec. http://www.brake-lines.co.uk/car-brake-lines/toyota/supra.html Great price too, especially with free delivery and 10% promo. tenner cheaper than buying direct from Hel. Quote Link to comment Share on other sites More sharing options...
