spiderpigcity Posted September 13, 2010 Share Posted September 13, 2010 I have an immaculate J SPEC 1997 3.0 N/A 6 speed manual for breaking, COLOUR 6N0 = Moonstone with veilside kit and new 19" alloys [ATTACH]117160[/ATTACH] DRIVERS AIRBAG £50 [ATTACH]118837[/ATTACH] [ATTACH]118838[/ATTACH] PASSENGER AIRBAG £90 POSTED [ATTACH]118166[/ATTACH] [ATTACH]118165[/ATTACH] ELECTRIC AERIAL GETS STUCK ON WAY DOWN STICKS OUT 6 INCHES BUT CAN BE FIXED OR MOTOR AND GEARBOX USED £10 POSTED CRANK DAMPER £15 POSTED MAIN INLET MANIFOLD £35 [ATTACH]117968[/ATTACH] SONY DOUBLE DIN MD/CD COMPATIBLE WITH CD PLAYER AND TAPE PLAYER £25POSTED wx-c770 model [ATTACH]118054[/ATTACH] [ATTACH]118055[/ATTACH] WINDOW REGULATOR WITH MOTOR PASSENEGER SIDE £40 POSTED AIR BOX £35 POSTED [ATTACH]117101[/ATTACH] [ATTACH]118754[/ATTACH] [ATTACH]118755[/ATTACH] WINDOW SWITCH PANEL DRIVERS SIDE £20 posted WINDOW SWITCH PANEL PASSENGER SIDE £18 POSTED BARE SHELL 1997 with(MOT until next year and V5 and service book). £550 PLUS DELIVERY PAINT CODE 6N0 MICA GREYISH GREEN -----SOLD----- REAR BUMPER MICA GREY WITH FOGLIGHT £30 ----SOLD----- [ATTACH]118167[/ATTACH] FUEL PUMP £15 POSTED SPACE SAVER WHEEL £34 posted FRONT PASSENGER SEATBELT £25 POSTED RADIATOR £30 GOOD CONDITION [ATTACH]117309[/ATTACH] PLASTIC RADIATOR COWLING UPPER AND LOWER £25 POSTED -----SOLD---- [ATTACH]118753[/ATTACH] FUEL PUMP RELAY £15 POSTED FUEL RAIL £20 POSTED [ATTACH]117965[/ATTACH] WATER PUMP £15 POSTED [ATTACH]118056[/ATTACH] THERMOSTAT COMPLETE HOUSING AND THERMOSTAT £20 POSTED [ATTACH]118177[/ATTACH] 2ND CAT £35 POSTED 1ST CAT £35 POSTED [ATTACH]118357[/ATTACH] STEERING WHEEL WITHOUT AIRBAG £30 POSTED [ATTACH]118839[/ATTACH] CAM BELT COVERS MIDDLE £15 POSTED [ATTACH]117886[/ATTACH] BACK CAM COVER PLASTIC £10 POSTED [ATTACH]117897[/ATTACH] CAM COVER LOWER £15 POSTED [ATTACH]118080[/ATTACH] THROTTLE BODY £35 POSTED [ATTACH]117895[/ATTACH] INJECTORS ALL 6 £30 POSTED CAM PULLEYS X 2 £15 POSTED [ATTACH]117894[/ATTACH] CRANK SENSOR £20 POSTED RADIATOR HOSE TOP & RADIATOR HOSE BOTTOM £10 POSTED WASHER BOTTLE £20 POSTED [ATTACH]118355[/ATTACH] COOLANT RESERVOIR £15 POSTED BRAKE SERVO & BRAKE MASTER CYLINDER AND RESERVOIR£30 POSTED DRIVERS DOOR BARE PASSENGER DOOR BARE GLOVEBOX LOWER £35 POSTED DOOR HANDLES EACH £15 POSTED REAR SPEAKER GRILS PAIR £7 POSTED FRONT ROLL BAR £18 posted [ATTACH]118354[/ATTACH] REAR ROLL BAR £15 POSTED MANIFOLD HEAT SHEILD £13 POSTED [ATTACH]117887[/ATTACH] HEATER MATRIX & FAN FULL ASSEMBLY £150 POSTED NA ENGINE LOOM £75 POSTED FUEL TANK £38 POSTED REAR WIPER MOTOR £35 POSTED [ATTACH]118168[/ATTACH] FRONT WIPER MOTOR £35 POSTED FACELIFT DASH PANEL RIGHT BARE £25 POSTED [ATTACH]118058[/ATTACH] FACELIFT DASH ABOVE CLOCKS £25 POSTED [ATTACH]117957[/ATTACH] FACELIFT DASH PANEL THAT GOES AROUND CLOCKS - £25 POSTED ALL COME WITHOUT CARBON EFFECT TRIM [ATTACH]117977[/ATTACH] 180MPH FACELIFT CLOCKS WITH MANUAL ODO SHOWING 52,000 MILES ----- £100 POSTED [ATTACH]117978[/ATTACH] ABS PUMP AND CONTROLLER £50 POSTED [ATTACH]117879[/ATTACH] VARIOUS SENSORS FROM ENGINE ----- ASK WITH PART NUMBER----- DISTRIBUTER £20 POSTED [ATTACH]117884[/ATTACH] TOYOTA HT LEADS & dissy cap £15 POSTED [ATTACH]117888[/ATTACH] IGNITER FOR IGNITION £25 POSTED REAR VIEW MIRROR IF I CAN GET IT OFF £10 POSTED AIR CON COMPRESSOR £40 POSTED [ATTACH]117892[/ATTACH] PLASTIC FRONT BUMPER INSERT BEHIND AIR CON RAD £15 POSTED [ATTACH]117970[/ATTACH] FAN PULLEY £10 POSTED [ATTACH]117883[/ATTACH] OIL FILTER MOUNT - £20 POSTED [ATTACH]117969[/ATTACH] DIPSTICK AND HOLDER - £10 POSTED [ATTACH]117963[/ATTACH] airbag drivers airbag prassenge boot light BOOT PLASTIC OS window regulator ns 1st na cat 2nd na cat 6 INCH SILICONE HOSE 6 injectors abs front hubs SOLD abs module abs pump accelerator cable aem maf sensor air con compressor air con rad SOLD airbag module airbox aireal alloys SOLD alternator SOLD ANTI ROLL BAR FRONT ANTI ROLL BAR REAR ashtray SOLD auto accelerator pedal auto box auto brake pedal auto surround SOLD auto surround under gearstick badge SOLD bare shell battery cover SOLD battery tray BILSTEIN SHOCKS SOLD bonnet clasps bonnet rear clasps bonnet rubber rear boot blind SOLD boot blind rollers boot carpet SOLD BOOT PLASTIC NS boot plastic rear lights boot struts SOLD bottom end brake calipers SOLD brake master cylinder brake servo BULB FAILURE MODULE CAM BELT TENSIONER SOLD cam cover lower cam cover middle cam cover upper SOLD CAM FASTENERS CAM PULLEYS X 2 cam shafts Cam wheels carbon dash SOLD carpet SOLD cente console rear SOLD CENTRAL LOCKING UNIT NS CENTRAL LOCKING UNIT OS centre console upper SOLD charcoal canister tt SOLD clock surrounds CRANK DAMPER crank pulley SOLD CRANK SENSOR cylinder head dash bare SOLD dash left SOLD DASH SURROUND OVER ABOVE CLOCKS dash trim right dash wiring loom dashboard SOLD dimmer switch dip stick DIP STICK HOLDER AND TUBE distributer distributer cap & leads door glass front ns door glass front os DOOR HANDLES NS DOOR HANDLES OS DOOR HINGES NS DOOR HINGES OS DRIVERS DOOR BARE drivers seatbelt SOLD ecu SOLD ecu tt SOLD ENGINE MOUNTS NA engine wiring loom EXHAUST GASKETS NA exhaust manifold tt exhaust manifoldna expansion tank facelift clocks FAN PULLEY fmic SOLD FOOT REST front calipers SOLD Front driver doors front hubs SOLD front hubs SOLD front passenegr door front roll bar front seats SOLD FRONT SUBFRAME front wiper assembly and motor front wiper motor FUEL PUMP CONTROL UNIT FUEL TANK FUSE BOX FRONT WING INTERNALS WITH LOOM FUSE BOX LOWER AND UPPER COVERS gearknob SOLD GLOVEBOX LOWER handbrake HANDBRAKE SURROUND RUBBER headlights SOLD heated screen module heater matrix heatsheild exhaust idle valve SOLD IDLE VALVE SOLD ignition coil SOLD ignitor indicator stalk indictors SOLD INJECTORS interior door handle ns interior door handle os KICK PLATE NS kickdown switch SOLD levoc gear SHIFT SOLD LOCK SET AND KEY main inlet manifold na manual switch TT na fuel pump na fuel rail O2 SENSOR TT oil filter mount PASSENGER DOOR BARE PLASTIC FILLER PANEL BETWEEN AIR CON RAD AND BUMPER PLASTIC SHIN PLATE (HAS BONNET RELEASE FASTENED TO IT) POLYSTRENE CRASH ABSORBER REAR BUMPER polystryene right polystyrene left POWER STEERING MODULE power steering pump and 02 sensorsx2 SOLD quarter light glass ns quarter light glass os radiator RADIATOR HOSE BOTTOM RADIATOR HOSE TOP radiator lower cowl SOLD radiator upper cowl SOLD rear calipers SOLD rear hatch cover SOLD rear hatch rubber side blocks rear hatchback rear hubs SOLD REAR LIGHT CLUSTER HARNESS NS REAR LIGHT CLUSTER HARNESS OS rear lights SOLD rear quarter lights rear roll bar rear seat lower SOLD rear set upper rear speaker grills rear subframe rear wing SOLD rear wiper motor roof liner seatbelt left rear seatbelt left right seatbelt lf shocks & springs SOLD side skirts SOLD SMALL INLET MANIFOLD SPACE SAVER WHEEL SPARK PLUG PLASTIC COVER REAR spats SOLD SPEAKER BOX FRONT NS OEM SPEAKER BOX FRONT OS OEM SPEAKERS FUSION MIDS 6.5 speedo clocks starter motor SOLD steering column steering rack SOLD steering wheel stereo sun visors SOLD THERMOSTAT AND COMPLETE HOUSING THROTTLE BODY THROTTLE POSITION SENSOR TRACTION RELAYS tt fuel rail upper dash underside UPPER FRONT CONTROL ARM NS UPPER FRONT CONTROL ARM OS vacuum sensor vapour charcoal canister viscous fan SOLD washer bottle waste gate tt SOLD WATER PUMP window regulator drivers SOLD window regulator passenger window seal SOLD WINDOW SWITCH NS WINDOW SWITCH OS windscreen plastic cowel [ATTACH]123669[/ATTACH] @@@@@ PLEASE NOTE THAT THE P&P PRICES AR FOR MAINLAND UK. SO PLEASE LET ME KNOW IF YOU ARE OUTSIDE THAT AREA AS POSTAGE WILL BE MORE@@@@@@ Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted September 13, 2010 Share Posted September 13, 2010 Why are you breaking it fella? seems a massive waste! Link to comment Share on other sites More sharing options...
Havard Posted September 13, 2010 Share Posted September 13, 2010 How much for the front seats? Why are you breaking? H. Link to comment Share on other sites More sharing options...
spiderpigcity Posted September 13, 2010 Author Share Posted September 13, 2010 Why are you breaking it fella? seems a massive waste! Converting my auto to 6 speed and bought it at the right price. Link to comment Share on other sites More sharing options...
spiderpigcity Posted September 13, 2010 Author Share Posted September 13, 2010 How much for the front seats? Why are you breaking? H. was toss up between boostlogic autobox (£2000), Lsd and all other bits probably another £1000, for my tt t67 but i have aem and its hard to get a mapper in the uk to do an auto. So i thought i would get rammed in and buy a 6 speed v161 car and rape it of the box and leave the rest for you guys. had my auto in the garage for 3 years and thought it was time to get around to doing something with it. Link to comment Share on other sites More sharing options...
Havard Posted September 13, 2010 Share Posted September 13, 2010 was toss up between boostlogic autobox (£2000), Lsd and all other bits probably another £1000, for my tt t67 but i have aem and its hard to get a mapper in the uk to do an auto. So i thought i would get rammed in and buy a 6 speed v161 car and rape it of the box and leave the rest for you guys. had my auto in the garage for 3 years and thought it was time to get around to doing something with it. Front seats? Price? Any pics? Cheers H. Link to comment Share on other sites More sharing options...
supra steveo Posted September 13, 2010 Share Posted September 13, 2010 pics ? prices ? Link to comment Share on other sites More sharing options...
RobD Posted September 13, 2010 Share Posted September 13, 2010 Pics of the 19's please Link to comment Share on other sites More sharing options...
laamaporo Posted September 13, 2010 Share Posted September 13, 2010 PMd about brakes and lights. Link to comment Share on other sites More sharing options...
RobD Posted September 13, 2010 Share Posted September 13, 2010 Maybe a price for the shell also but must have dash etc Link to comment Share on other sites More sharing options...
scotty71 Posted September 13, 2010 Share Posted September 13, 2010 How Much for the front lights? How much for the indicator looms/clear indicator front lenses How much for the Ash Tray (if its not broken) In Derbyshire also so could pick these up Link to comment Share on other sites More sharing options...
JODY T Posted September 13, 2010 Share Posted September 13, 2010 They never fitted a vvti na to a supra mate, are u sure it's vvti? Link to comment Share on other sites More sharing options...
j_jza80 Posted September 13, 2010 Share Posted September 13, 2010 Put the 6 sped box back in it and sell the whole lot to me, nice and cheap Link to comment Share on other sites More sharing options...
JODY T Posted September 13, 2010 Share Posted September 13, 2010 How much for the drivers hub and the passenger rear top arm? Could give me a price on the whole rear subframe also Link to comment Share on other sites More sharing options...
Neil-NA Posted September 13, 2010 Share Posted September 13, 2010 What kind of suspension has it got? if they are Bilsteins i will take em if price is right Link to comment Share on other sites More sharing options...
supra steveo Posted September 13, 2010 Share Posted September 13, 2010 price for facelift front wings? oh and pictures Link to comment Share on other sites More sharing options...
monza786 Posted September 13, 2010 Share Posted September 13, 2010 also what colour are the front seats pmd too Link to comment Share on other sites More sharing options...
TTRickeh Posted September 13, 2010 Share Posted September 13, 2010 PM'd Link to comment Share on other sites More sharing options...
Thomas_germany Posted September 14, 2010 Share Posted September 14, 2010 PM'd Link to comment Share on other sites More sharing options...
gazzi123 Posted September 14, 2010 Share Posted September 14, 2010 price for driver + passenger rubbers around windows (including rubbers around mini window for passengers? (if they are in good condition - Notgrey or weatherd) cheers Link to comment Share on other sites More sharing options...
davej705 Posted September 14, 2010 Share Posted September 14, 2010 Any facelift rear lights going? Link to comment Share on other sites More sharing options...
neo2810 Posted September 14, 2010 Share Posted September 14, 2010 I'd also be interested in the headlights if they are in good nick. Clear front and side indicators (dibs if so)? Link to comment Share on other sites More sharing options...
JamieP Posted September 14, 2010 Share Posted September 14, 2010 Bad idea, you are going to get 1000's of pm's, i had a nightmare with pm's when i broke the orange supra, i bet you get loads of pm's asking how much for the 6 speed box even though you have already said you are keeping it:D Better to just break it up, list all the parts with prices. Link to comment Share on other sites More sharing options...
Havard Posted September 14, 2010 Share Posted September 14, 2010 Bad idea, you are going to get 1000's of pm's, i had a nightmare with pm's when i broke the orange supra, i bet you get loads of pm's asking how much for the 6 speed box even though you have already said you are keeping it:D Better to just break it up, list all the parts with prices. I have already pm'd Matt..... Link to comment Share on other sites More sharing options...
bradleyh_15 Posted September 14, 2010 Share Posted September 14, 2010 Do you have The passenger side front vented wheel arch liner? Front drivers side calliper if it's a 2 pot? Pm me if you like! Link to comment Share on other sites More sharing options...
